    Results 1 to 20 of 37
      Oct 2009
      Southeastern Michigan
      1984 Monte Carlo SS
      Picked up an uber-clean '84 MCSS roller from my bro-in-law last year. A half-baked idea lead to rampant impulse spending.
      The goal:
      PT-esque build with emphasis on driveability and reliability. The A/C has to work, too. Heavy fabrication modifications will be avoided- no notching, no cutting, no welding on the car. Must be able to be returned to stock. Pretty crappy and expensive design constraint but I feel the car is way too clean to hack up.
      Drivetrain:
      '01 5.7L LS1 / 4L60E w/ 52k bought from Cleveland Pick-A-Part.
      BRP mid-length headers, RetroLSX oil pan, Spohn motor mounts, and Iceman X-member are only noteworthy mods. Rear axle has Richmond gears 3.58 or 3.73 (I have to verify) and limited slip.
      Front suspension:
      SC&C Stage 2, SPC LCAs, SPC coils, Varishocks, SC&C frame brace, Baer 13" Track brakes
      Rear suspension:
      Currie UCAs, Currie LCAs, SPC coils, Spohn PT sway bar, Varishocks, Baer 13" Track rear brakes.
      Wheels & Tires:
      Round aluminum chunks wrapped in black rubber.
      Before viewing the photos, yea, I totally skipped stripping and painting the frame. Maybe this winter, maybe next winter I'll get around to it. Probably not and I'm ok with that.
      Photo journal:
      Day I brought it home and washed it:
      Drivetrain ready for fitment:
      It's in the hole!
      Wiring is done until the front clip is reinstalled
      The mess up front. Welding LBJs tomorrow will complete installation this week.
      Out back:
      Out back again, where the 'vette filter/regulator resides:
      Anybody recognize this LSD?
      And that's about where I've stopped as of today. This week my goals are to finish the front suspension and brake installation, and rear disc conversion.
      Next steps after installing suspension and brakes:
      - reinstall front clip and finish wiring
      - install fuel tank and connect lines
      - stalk the loading docks daily for my wheels & tires
      - adjust suspension, order driveshaft
      - have exhaust system fabbed
      - window tint & detail
      Due to work schedule and having two energetic toddlers, hoping to be driving by October 1.
      May 2007
      This is a great project. In fact I've had the same thing rolling around in my head. How are you doing ECU, tranny, fuel, etc to make this swap work?
      Woodbine, MD
      looking good!!!
      Douglas Lutes
      1988 Monte Carlo SS
      Mar 2010
      Looks awesome man. Can't wait to see some pictures of it when its on the ground. Want to see the ride height with those springs. Im thinking about putting them in my Malibu.
      keep up the good work. that thing looks like its gonna be fun to drive
      memphis
      That's a clean roller...
      Dave
      Sep 2009
      That's a nice project. I had a 1987 MCSS that was in now where near as good of shape. Nice project.
      nice project!!! what rear end is it? 8.5?
      Oct 2009
      Thanks for the kind words, all.
      Quote Originally Posted by titan460 View Post
      Factory computer. My wiring harness was twice modified. First modification was convert it to stand alone. Second modification was to correct workmanship issues with the first mod, then extend ECU leads so it could be mounted behind the glove box. I'm using two fuse blocks. The OEM block handles chassis electrical. A Current Performance block handles the engine.
      Trans: factory controls. Trying to make OEM 200R4 shifter play nice with 4L60E.
      Fuel: BGN fuel tank, BGN in-tank fuel pump and sender, 'vette filter/regulator, -6AN lines to factory fuel rails
      etc: Shiftworks mechanical speedo converter, Kwik A/C relocation bracket, will probably swap out steering shaft to eliminate rubber bushings and plastic cladding too close to headers. Planning to use stock F-body radiator and fans for cooling.
      Honestly, I haven't fact-checked the rear axle. I don't know if the carrier is factory, it looks aftermarket.
      Nov 2007
      Looks like a great project, you're really moving along!
      Erwin,TN
      Very nice project.
      Feb 2009
      Stevensville, MI
      Nice project. It looks like my cutlass back in 2002.
      Great project!
      I will be interested in hearing how the Vari-shocks act.
      1985 Monte Carlo SS- 224/228 cammed 5.3/4L80E/17x9.5 Budnik Tiller 5s/BFG Comp T/As
      2007 2500HD Silverado CCSB Duramax- 18" KMC HOSS, 285s
      2006 Corvette Coupe- Black/LS2/M6/3LT/Corsa/Callaway MP112/Nitto Invos SOLD
      2002 Sierra Denali Quadrateer-
      SOLD
      Oct 2009
      Copperas Cove, TX
      Nice!!! I love all of the Montes on PT now.
      Andy McCatherine
      1982 Monte Carlo SS (clone)
      Oct 2009
      Quote Originally Posted by shudog View Post
      The progress efficiency illusion is the magic of the internet. 10 months have transpired between first and last photos.
      I'm hoping to recover from last weekend's setback and finish what I set out to do last weekend. Wheels are due Tuesday, gotta be ready.
      Nov 2009
      Colorado
      Damn! I am so jealous that's what my plans are for my Grand Prix...
      As for the posi unit it looks like my old Auburn posi unit that i sold.My came with stock 3.42 gears If you take it off it should look like this:
      Hope this helps.
      Ernesto M.
      Woodbine, MD
      Quote Originally Posted by somcamaross View Post
      Great project!
      I have vari-shocks on my monte. They perform perfectly!
      Douglas Lutes
      1988 Monte Carlo SS
      Oct 2009
      The rolling stock arrived today.
      Rushforth Fuel in smoked titanium with polished outers. 18x7 up front, 18x8 out back, rolling on Hankook Ventus V12 235/40 front and 255/40 rear.
      San Antonio, TX
      Very nice build! And my favorite year SS too!
      McKinney, TX
      Looks great. nice job.
      89 Mustang "Box Wine"
      Erwin,TN
      Quote Originally Posted by cornfed View Post
      Looks great!! It is especially good that you are starting from a basically sound car.
