Thread: Pro-Touring Trike - In Theory
05-08-2005 #1
Moderators, if this is too far-fetched and you have to "file" it in the Outhouse, I understand.
I had a crazy brain fart a few days ago, did some surfing, found some interesting info, and now am more curious than ever about whether or not a trike can handle like a sports car???
He is speaking of a rear-engined, VW-based, trike. His theory is based on the fact that the COG is lower and much further back than a motorcyle based trike, and that gravity and inertia acting on this low rearward COG will cause the vehicle to rotate rather than tip - allowing it to corner so well....Rear engine Trikes sit on the road like a go-kart and if anything you can make them slide sideways or do donuts, but you can't make them tip over no matter what you do.
I have proven many times that our Trikes go faster around corners than any other motor-vehicle on the road today. On a tight corner race track no motorcycle or sports car can go as quick as a rear engine Trike...
IF this theory is sound, one would be able to build a transverse mid-engined trike, instead of the rear-engined VW type, and a relatively tight rear suspension - all designed to make the rear end rotate PREDICTABLY under power. Or would one end up taking an enclosed joy ride to the local emergency room
Todd Perkins
todd's hot rods
05-09-2005 #2wouldnt you think a trike would have a tendency to understeer? Maybe you could install tractor brakes to make it turn better? And i bet i could flip one over i'm pretty good at testing a vehicles limits. Sometimes it hurts though.
05-09-2005 #3
Full Blown G-Machiner
- Sep 2004
- PA.
- 935
