    Results 1 to 10 of 10
      Jun 2009
      Ridetech Airpod or ??
      I have a set of Shockwaves for my '56 Chevy and soon I need to buy the control unit. Is the ridetech Airpod really easy to install?
      Is it worth the money?
      What are my other options for controlling the shockwaves?
      I'm new to the air suspension world.
      So. Cal.
      The air pod looks nice cause its all contained and it will be the quickest way to plumb the shockwaves. I bought shockwaves for the front and rear and their controller and air valves, along with two pumps. I had some packaging issues so an air pod would not fit.
      Now as far as controllers go Im not sure because I havent used any others. I have the ART controller without the height sensors. If I had the money at the time I would have gone that route. But all they had was levers/sensors that mounted on the frame and suspension to check ride height. I could not configure those into my suspension anyway.
      BUT.... They have the shockwaves with integrated sensors now. That to me seems nice the perfect setup. JR
      I have the airpod, but I ended up mounting it on a different board after I changed my mind on where I wanted the subs. Hooking everything up was easy... its all labeled. I believe it is pressure tested before they send it out as well. Mine had no leaks.
      If you enjoy doing wiring and such they had good diagrams in the instructions for the controller. So it should not be to hard to do from scratch. Depends on your preferences/skills as to wether its worth the money.
      My VW friends use accuair for controllers... no issues that I have heard of.
      Pete
      May 2009
      Florida
      call Reno at AccuAir - their air mangement system is reliable, excellent quality components, and very user friendly. They are sponsors here
      Jacksonville, FL
      It depends on what your plans are for your trunk area. I had already bought the kit (4100l) and made my own "airpod". Used the dimensions on their website and went from there. From a packaging/installation stand point; if your budget and your trunk layout will allow, get the airpod. One thing I will say about ridetech is that their customer service is one of the best out there!
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Indiana
      If you want the easiest solution, have the room, and can spare the bit of extra change...the AirPod is pre-assembled, pre-plumbed, and pre-tested. 4 bolts, 3 wires, 4 airline connections.
      If you need to hide the components, if you have time to spend mounting components, running airlines and wiring [it's not hard at all], and want to save some money...the regular e3 compressor kit is exactly the same components, just not pre-assembled for you. You can save about $400.
      Our customers seem about evenly split...50% go for the AirPod.
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      i have the airpod mounted in the trunk....really easy to install and wire....
      I used rubber mounts to mount it on the floor....
      the cover is really disappointing....the screws that come with it do not hold it in place and it rattles like no tomorrow....extremlly annoying....I am about ready to pull it and toss it...
      So. Cal.
      Quote Originally Posted by bret View Post
      Hey Bret. I love all of the ride tech stuff, and the people supporting the product. Kinda goofy but I think your strong point is tech support. Yeah!! As nice as the product is and really doesnt need any tech support Im blown away everytime I get on the phone and there is an actually a knowledgeable guy answering the line and wanting to help me out. I dont know who designed that or if its just a fluke because you have a bunch of guys that actually know the product line. What ever it is... It works. Kinda refreashing. You may not even know how many manufactures are disconnected from the customer.
      So anyway, nuff azz kissing. The pod is a nice plug and play system. But..... I did a diff system. Cut ALOT of wires and re-routed them. Used stainless braided hose, not because the lines that were provided were not up to the task, just my own issue.
      Check out my air ride "air pod" LOL JR
      https://www.pro-touring.com/forum/sh...ad.php?t=70049
      Indiana
      Just to clarify...the AirPod components [compressor, tank, solenoids, ECU, etc.] are the same as the regular compressor kit EXCEPT the wiring harness is customized for the AirPod [length and routing]. If you get an AirPod and decide to take it apart and custom mount the stuff...by all means let me replace it with a regular compressor kit that has the longer, universal wiring harness. No need to pay extra for the AirPod and then cut apart the wiring harness to perform a custom install.
      Bret Voelkel
      So. Cal.
      Not sure if this was kinda meant for me but I didnt buy an air pod. I bought the "standard kit" and re-wired it for my needs. Not to say I havent done ALOT of backward building JR
