    Results 1 to 10 of 10
      Opening an upper A-arm plate
      Not sure if this should go in suspension or fabrication-
      I'm planning on using Howe extened ball joints on an aftermarket upper A-arm.The balljoint plate is about 5/16" thick, and the Howe BJ is bigger than the hole in the plate. Suggestions other than a dremel to open thehole diameter? I dont have a mill to bore the hole.
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
