    Results 1 to 9 of 9
      Sep 2009
      LA,CA
      Difference between L92 and LS3
      What are the main differeces between a L92 and LS3? Swapping out old for new. Engine is for a 69 Camaro.
      Mayfield, KY
      Quote Originally Posted by Danksta14 View Post
      L92 - VVT (variable valve timing) and big ugly truck intake
      LS3 - No VVT and has better looking car intake
      I have the L92 myself. I wanted to take advantage of the VVT, so I kept it and put the LS3 car intake on it.
      Rod Keeling
      '67 Camaro Mast L92 / 4L80E (work in progress)
      http://www.hubgarage.com/mygarage/RodDawg
      Jul 2007
      sweden
      yepp
      Quote Originally Posted by roddawg View Post
      i have the l92 myself. I wanted to take advantage of the vvt, so i kept it and put the ls3 car intake on it.
      = l99
      camaro69-l92 with 6l80e considering mast ho cam 530hp - speedtech(LCA)-ats Street-Comp AFX-unisteer r&p - VariShock coilover QuickSet2-Hydratech Brake Booster - 5gen rear suspension
      movit brakes 380mm 6piston front-465mm 4piston rear - 275/30-19 front-325/25-20 rear 19x9f 20x12r cray scorpions
      Mayfield, KY
      Quote Originally Posted by holschen View Post
      = l99
      Yeah. They weren't available when I bought mine, and you still probably would want to do away with the DOD (displacement on demand) that comes on the L99. I bought a L92 crate and went to Mast for parts.
      Rod Keeling
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Mayfield, KY
      Quote Originally Posted by neki67 View Post
      LS3 valves are hollow and thus lighter than the L92 solid valves.
      You're right. I forgot about that being different too.
      Rod Keeling
      Jun 2008
      I have a motor that i have been told is an ls3, how can i tell that its an ls3 not an l99 or l92?
      Mayfield, KY
      Quote Originally Posted by Oz69camaro View Post
      I know the VVT engines have different water pumps, and the L92 has the huge intake.
      If it has not been modified, it should look like the first pic.
      LS3
      L92 (Should be the easiest to spot with the intake and VVT truck water pump)
      L99 (underneath should be the same looking intake as the LS3)
      Rod Keeling
      Jun 2008
      Quote Originally Posted by RodDawg View Post
      LS3
      Cheers for the info, looks like i have an L99. Might have to take advantage of the vvt.
