    Results 1 to 10 of 10
      Jul 2007
      Custom Dash install
      I'm thinking about installing this dash into my 69 Bird. Don't quite know exactly where I need to start though...and I'm working backwards...the car's in the paintshop now, so I'll be installing after paint....any advice?
      Jul 2007
      Nobody's done anything similar?
      Nov 2009
      AR
      I come from a BMW background...
      You'll need to measure the dash across & to the windshield. Start figuring out how to attach & brace it.
      From there start figuring out steering columns, A/C venting & connections.
      Are you gonna use the BMW gauges & steering wheel?
      1972 Pontiac LeMans Luxury
      Jul 2007
      I plan on using Dakota Digitals in the BMW gauge housing. Steering rack possibly the 3series rack.
      May 2001
      Mesa, Az.
      I had thought about doing that same swap at one time into a Corvair that I had. Dimensions were very similar. Ended up selling the car to a friend.
      Phillip
      Colchester, Ct.
      I know we have a few members that have changed dashes from a late model GTO into a first gen camaro
      'Veteran' --is someone who, at one point in his life, wrote a blank check made payable to 'The United States of America,' for an amount of 'up to, and including his life.'
      CT
      Im just about done installing a 04 GTO dash in my car. Start by measuring the new dash and distance between pillers. Take in to account what your going to do for door panels and where your steering column is. If everything looks like its going to fit. Take out the windshield, take everything out from under your dash and cut off the old dash. mock up everything even steering column. Dont forget the Glass. Make bracket that allow you to make small adjustments.
      Have fun and patients.
      Jul 2007
      Thanks Sunkist.
      Looking at the measurements, I think I'll have more than an inch on both ends. Since I'll be making the door panels, they'll have to curve in a bit.
      CT
      Sounds like your in good shape.
      How does it look against the windshield?
      Nov 2009
      AR
      just saw this post you might talk to this guy as well....https://www.pro-touring.com/forum/sh...ad.php?t=67351
