Thread: 8.5 10 Bolt A-Body
- Jun 2010
- 11
8.5 10 Bolt A-Body
Hi, i was wondering if maybe someone here can help me id the rear end that i just bought, it is a 8.5 10 Bolt, has 3 Large "A" stampings on it, 1 on the top of the pumpkin and 1 on each side, the cover is the irregular one, i was told it came form a 71 Cutlass but cant know for sure, it has LCA similar to those on my GTO but they have holes drilled for sway bars and they look like factory made holes, BUT i was told that all LCA that came with the sway bar holes were boxed and this arent boxed. ok, going back to the rear end, i found the following cast in the passenger side axle tube: SA B263 1, i just couldnt find ANY info on this stamping, anyone out ther has ANY info about what it may be?, i know this is not a Posi, and i know that i can check the teeth numbers to see what ratio i have, but if someone can help me before i tear it apart, that`ll be great.
Thanks A Lot.
