    Results 1 to 10 of 10
      Wichita, KS
      Swage Fitting Leaking / Vintage Air / Need Help
      I have a vintage air system and the high side of the compressor swage fitting is leaking. I put about 3 cans of R-134 in a few months ago and the A/C temp was getting warm. I hooked up the gauges and put a can of UV and 2 cans of R-134 in there and now the low side is at 40psi with high side at 270psi.
      I ran the car around today with A/C on high and I took the black light to the engine bay. I notice the swage fitting on the high side of the compressor to the hose is leaking. This is the only leak I found so far.
      These swage fittings don't use o-rings do they? I have taken the compressor off a few times lately and for some odd reason I think I lost an o-ring. A friend told me swage fittings don't use o-rings, but I am not sure if he is right or not?
      Thoughts? Suggestions?
      Brian
      Mountain Springs, Texas
      If you're talking about the hose connections to the compressor, yes they use an o-ring.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Wichita, KS
      Here is exactly where I am talking about. If you look at where the red arrow is pointing you can actually see the green dye. Does this fitting use an o-ring?
      I think there should be an o-ring in there.
      Wichita, KS
      Yeh, I kinda thought so too. I think there was at some point but I have had the front runner kit off so many times that I think the last time I took it all apart the o-ring fell out. I think it's a #8 or #10 o-ring.
      I have another issue though.... Maybe you can shed some light on it. When I first put the vintage air kit in about 3 years ago the a/c was so cold it was like a darn freezer blowing air at you. Now it seems when fully charged (low side at 40psi / high side at 260psi) I don't quite get the same temp coming out. It's cold but not like it used to be. I used to get frost on the upper part of the center vent it was so dang cold blowing out of there. Now it's just somewhat cold but nowhere like it used to be.
      One of my buddies suggested getting a vacuum and evacuating everything out of the system and then recharging it. I don't have a vacuum and I prefer not to buy one unless it's really going to fix my problem.
      Also... I am using off the shelf R-134 cans. If I remember correctly when it used to be ice-box cold I was using refrigerant out of my friend's tank. Not sure if that makes a difference? R-134 should be R-134 right? Or wrong?
      Thoughts?
      Brian
      I'm not an expert but since you have a leak I would get a vacuum pump and follow these charging instructions:
      http://www.vintageair.com/DownloadsS...structions.pdf
      The local Autozone here lends out vacuum pumps and gauges for free.
      Your low side pressure sounds high. These Vintage Air systems run at different pressures than factory air systems. I think it is because they run much lower cold temperatures and rely on a thermistor to detect near freezing temperatures and then turn on the heat a little. They are also quite sensitive to the amount of R134 that you use. Use the exact amount they specify.
      Maybe one of the experts will give an opinon too.
