Results 21 to 40 of 41
- Nov 2007
- Oro Valley, AZ
- 80
I guess you're right... I saw 450 somewhere, that was probably a short- or long-block. I found this after a little searching.
http://www.team.net/sol/tech/engine.html
06-20-2010 #2
- Mar 2009
- Southern Maryland
- 402
Good info, it shows the 2.3l which I have as around 420 and the smaller v6's in the 305-380lb range depending on displacement. Thought it would have been the other way around. Maybe that's part of what makes the 2.3l hard little motors, dunno?
From looking around it looks like the 2.7l MB engine, called the OM612 should weigh around 470. So these turbo diesels I'm looking at are going to be equivalent to a small block swap.
Edit; I posted a thread on TDI Club forums looking for the TDI engine weight. First response was 450, now someone said it's much closer to 350lbs. If that's the case that makes the tdi much more appealing. I will keep looking for better info on the om612.Last edited by joemac; 06-20-2010 at 08:07 AM.
06-21-2010 #3
- Jun 2008
- green bay wisconsin
- 111
