    Results 1 to 19 of 19
    Thread: Red paint help
      Perth Western Australia
      Country Flag: Australia
      Red paint help
      Looking for a real stand out bright red for my project, help,
      Thanks in advance.
      Greg
      Used to be known as tonner
      Feb 2003
      St. Louis, Missouri
      Blue Blood Red. House of Kolor.
      Rick Butterfield
      Jan 2009
      Suisun City, Ca
      PPG---Peacock Red
      Michael Hunt
      Suisun City, CA
      Tallahassee, FL
      That PPG Peacock looks awesome!
      I went with Viper red...
      https://www.pro-touring.com/forum/sh...rodigy+customs
      Dec 2007
      British Columbia, Canada
      I'll second that Blue Blood Red from HOK!
      Carter
      Apr 2008
      Forest City,NC
      A little trick with any red thats not a candy or custom color that takes a certain base under it is to put down a bright yellow base,, like whats called chrome yellow or daytona yellow,,the brightest you can get before putting on the red base,,it makes it really pop,,dont know why but it does. use it under any red base and see the difference. try a panel with the yellow and one without,using the same red base,,then clear them and look at them outside.
      Mark Dorsey
      Jan 2009
      Jacksonville Florida
      If you want the brightest red, Ford Performance Red ,can be found on 93 Cobra or Ranger Splash,it looks almost like a florescent marker,but if you want the brightest red that's rich without looking orange in bright sunlight, Porsche Guards Red ,
      Obviously there are many choices when it comes to candy colors,just keep in mind, it's not going to be easy or cheap to match a candy color, if you have a mishap, but it's alot easier to mix a solid color for touch up and spot repair.
      Do what's right,not what's easy
      69 Firebird
      71 Cuda
      98 Supra 6speed white APU
      98 Lexus GS400tt widebody
      Elite Custom Body
      Stefan B.
      Rural Retreat,VA
      A bright non metallic red wa8774 code. Used on early 90s grand am and firebirds. just done a 78 vette in it and it is bright...
      Aug 2003
      Guess I kinda screwed you out of the yellow huh! Sorry!
      Below is a car we painted a couple years ago. We been on hold waiting for econimics to improve and just this weekend I got the go ahead to finish it. We are very excited. it is a super cool car with a LS7, Bowler 4l65E with Steve Os paddle shifter and converter. All DSE everything. Going to be a sick puppy.
      Color.
      Ferrari
      Corso Russo Red!
      Best red I have ever seen.
      I would not be worried about not using it because someone else did. I have some ideas for this color I will share with you.
      Mt.Pleasant Pa.
      PPG straight red toner nothing else added.
      71 olds cutlass supreme convertible
      07 dodge ram
      96 monte carlo
      11 dodge challenger
      http://www.fquick.com/724TIM
      http://s297.photobucket.com/albums/mm206/724tim/
      Thanks for all the replys, I will try to see some of them in the flesh.
      Greg
      Aug 2003
      I might show you the red car in Vegas
      Feb 2010
      browns mills, nj
      You didnt specify what type of red??? Im guessing you are looking into a solid color.Check out the BRIGHT red that is on the Mazda 3...Its very bright...I can get you the code tommorow.....here is a pic...
      Dec 2007
      Carlsbad, Ca
      vw salsa, or the one im going with; mercedes mars red. both are a little darker, but they are more classy and less in your face.
      Tim
      Build Thread Link
      Mar 2010
      Alabama
      I went with a torch red from 2000 Corvette and I like it. It is bright and just looks clean IMO.
      Lawrenceburg, TN
      go to your local paint shop if their like us... I have stacks of paint chart books, the only problem is you will have to many choices!! that's the reason I haven't painted my own car !!! choices, choices!! to many
      GOOD LUCK!
      Jul 2010
      Use a straight mixing color.For ppg, dmd 654.mix it as a base,
      or use 654 concept single stage,then clear it.That gives
      incredible depth. So it stays pure red,use a white sealer.
      UK London
      Quote Originally Posted by elitecustombody View Post
      Porsche Gaurds Red, Sprayed in 1993, touched up with spray can's in 2005. Total hood paint from Guards Red aerosol cans.....
