    Page 2 of 2 FirstFirst 1 2
    Results 21 to 23 of 23
    1. #21
      May 2002
      Southeastern WI
      Jeff,
      Both my rear shocks did the same thing, to the point that it wore off some of the threads on the shock body. I put it down as "racing parts on the street" and didn't worry too much about it.
      jp
      Good to know. I am going to pull it apart to check anyway, doesn't take long. I don't like how I have the right side cranked up near the top of the threads and the left in the bottom of the middle third and the car still sits low on the right. It sat that way a little with leafs, I just attributed it to the technology of leaf springs.
      Jeff
    2. #22
      May 2002
      Southeastern WI
      Here are my observations. QA1's recommendation for my shock is a 12" spring. Mine are 10", 275 lb. Would a lighter weight 12" spring cure my problem?
      In reading DHutton's post, with the Chassisworks setup a 200lb, 12" spring is recommended. From what I understand the Airbar system is very similar in design. My vendor might have given me a heavier spring knowing my car would see a fair amount of track use, but is it too heavy?
      I spoke with QA1 earlier. They need the rear weight of my car in order to recommend a spring, which I will get as soon as I can borrow my buddy's corner scales.
      Jeff
    3. #23
      Mountain Springs, Texas
      Quote Originally Posted by Van B View Post
      Nick from Chassisworks posted instructions for determining the correct spring rate in my post. You can use any springs (even your 275 pound ones) to determine the correct rate using the compressed length, uncompressed length and the desired shock compression at ride height. I'm going to try this when I get my shocks back.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
