06-12-2010 #1
spinnging ball joint & Castle nut.
I am trying to replace my front springs but then..... I finally got the castle nut loose enough to "pop" the ball joint from the spindle, then I put tension on the lower control arm to remove the castle nut, but now the castle nut and ball joint are spinning together so the nut can't be removed.
Suggestions are welcomed (please!!!). I need input on how to stop the ball joint from spinning so I can get the last 4 turns on the nut, in order to remove it.
I'm going to work on the other side, so I'll check back soon.
Thanks in advance.
Jeff
