      May 2010
      broken heli-coil help
      so i was putting in a new starter in my camaro (355) and as i was tightening the outer bolt i noticed it was sure turning alot so i pulled the starter back out and out falls a broken heli-coil right on my forehead, now i've never used heli coils before so i dont know what my next step should be any suggestions would be greatly appreciated
      Jan 2002
      Crockett, Texas
      Loctite?
      Don 67 Camaro RS/SS Texas
      Phoenix
      http://www.timesert.com/ These are much better than Heli-Coil
      Keensert is another one, pretty much the same thing.
      http://alcoafastener.thomasnet.com/c...bc=1041%7C1042
      Erik
      https://www.pro-touring.com/showthre...without-a-name
      Camaro LS2, T56, 12 bolt, C6 Z06 brakes, Rushforth Super Spokes, ATS Spindles
      2006 Chevy Trailblazer SS
      west michigan
      I use the ones Erik listed from alcoa at work all the time and am very happy with them. I never use helicoils. but the threaded inserts are alot nicer.
      Chad Read
      san diego
      If you are in san diego my hardware store sells all of these inserts.
      Apr 2008
      Newark, OH, / Concord, NC
      The Tme Serts are probably the best fix for your problem, here are some part #s to look at. Install the longest insert that will fit your application minus 1/8 to 3/16 inch for max thread engagement.
      KIT SIZE
      KIT
      PART NO.
      LENGTH
      INCHES
      CARBON STEEL
      STAINLESS STEEL
      3/8 - 16
      0381
      .312
      .400
      .520
      .620
      .750
      .900
      1.000
      1.200
      This is a dealer that I use that will ship anywhere in the country,
      Pendergrass Tool Specialist, 800-926-1847
      Dale
      IF COMMON SENSE WAS COMMON EVERYBODY WOULD HAVE IT
      May 2010
      k thanks for the info im gonna try to find those inserts locally(vancouver) and if not i'll order them off that site
      Apr 2008
      You can also get a product from Time Sert that will repair a thread that can't be fixed with a normal insert, it's called Big Sert, same principle just a larger outside outside thread.
      Dale
