      Crown Point, Indiana
      Dies under hard breaking
      What would cause the engine to die when braking hard in the corners on an auto cross. Every time I come into a turn hard and slam on the brake pedal the engine dies. Roots blower, manual brakes, and carbed.
      San Diego, CA
      I'm not sure if you're using vacuum advance, but I noticed this exact same problem when I had my distributor vacuum advance hooked up to the carb vacuum port. I then changed it to run off the intake manifold port and the problem went away completely.
      Chris Robinson
      1969 Camaro SS/RS G-machine/resto-mod
      Project site: http://www.69camaroproject.com/
      No vacuum advance. Locked out Msd billet dist.
      Feb 2002
      Springfield, MO
      Fuel slosh from the vent tubes on the carb IMO. Holley makes vent extenders that go inside the bowl area to keep that from happening. Not sure what they are called tho. I'll try to find them.
      Edit:
      found them. Vent whistles
      http://www.oreillyauto.com/site/c/de...1277&ppt=C0261
      And some tech for that problem:
      http://classicbroncos.com/carb_tricks.shtml
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      May 2002
      Northern California
      yep, or the float levels are just too high.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jul 2008
      ATL
      what do you have your idle set at? for competition you will need to run it at 1000 - 1200 600-800 is too low and will let it die
      HPDE is the greatest thing since sliced bread.
      So much to learn......so much $$ to do so lol
      Between 600 800
      Jul 2008
      ATL
      Quote Originally Posted by GRNOVA View Post
      Between 600 800
      I would recommend you increase this to 1000
