    Results 1 to 20 of 20
      Atlanta GA
      Best SBC headers for ground clearance?
      Already searched..
      So.. i slammed Stormy to the point that it grinds the Hooker headers regularly.. like 1 inch from the ground.. bad news.
      so i need to throw on some headers that clear and tuck up hard in the chassis.. im running a 383.
      who are you guys using?... shortys?... anything i could run up to Summit and scoop up?
      thanks fellas!
      Sep 2002
      San Jose, CA
      www.sandersonheaders.com
      Really good quality
      Just call me Brett
      Apr 2008
      I have headman shorties on my camaro. Im sure there are better choices but definetly no ground clearance problems with them and they are cheap.
      Mike A
      69 Chevelle
      496 Big Block
      Jacksonville, FL
      Stainless works has a nice setup that tuck nice, someone was trying to sell some recently on here. Thorley Tri-Y's also fit nicely.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Dunwoody, GA
      Don't go shorties unless you just don't have any choice. If long tubes aren't available, a quality built mid length will flow well and allow you the ground clearance you need. Shorties suck and should only be used if nothing else is available or you have emissions requirements to satisfy.
      Trey
      ~ Jon Hammond
      Monterey Peninsula
      Quote Originally Posted by 130fe View Post
      2nd on the stainless works headers,those will be your tightest fitting option,but they are pricy.
      I run 1 7/8 Hooker Super Comps and my car is pretty slammed and never had an issue.
      www.buickfunnycar.com
      Belle Plaine, MN
      I run the Hedman mid-lengths on my 383. Plenty of ground clearance on them.
      They are tricky to work with if you have angle plug heads, but most headers are. I've had to go to shorty plugs (I use ACCEL's) and they clear.
      Scott Parkhurst
      Mt.Pleasant Pa.
      Quote Originally Posted by 69496 View Post
      x2 have the same thing on my olds.
      71 olds cutlass supreme convertible
      07 dodge ram
      96 monte carlo
      11 dodge challenger
      http://www.fquick.com/724TIM
      http://s297.photobucket.com/albums/mm206/724tim/
      Atlanta GA
      i was looking at the Shortys.. but i heard bad things over the years..
      am i misinformed?
      i do want to stay cost effective.. it IS Stormy.
      Belle Plaine, MN
      bad things like..?
      Do they cost power vs. full-length pipes? Sure, but are still much better than manifolds or block huggers.
      Quality-wise, I've been running these Hedmans for more than 6 yrs with 2 different small-blocks, and while they could use a fresh coating job, they're fine otherwise.
      I've heard more bad things about Sanderson's offerings than Hedmans, by far.
      I have no problem recommending Hedman's parts. I'll keep using them. They offer plenty of clearance everywhere but the plugs, like I mentioned earlier.
      Scott Parkhurst
      Mar 2002
      Redwood City, CA
      Hedman 68600 intermediates. I have the emissions legal version on my '77 Camaro. No issues.
      Allen Ortega
      Feb 2008
      Sesser, Il
      Quote Originally Posted by zbugger View Post
      I've run these exact same headers and I loved them. 1 5/8" primaries. Mine didn't have the air tubes. They won't fit with merchanical linkage but fit great with an automatic. I could change all 8 plugs in less than a half hour. Only reason I pulled them off was I swapped to a mech linkage manual tranny.
      I bolted the headers to the engine and then dropped it all in the car at one time. I used the Percys alum header gasket with the Breslin (now Percy's) locking header bolts and never had an issue with them. I know, it has the Stage 8 locking bolts in the picture but those were tossed after I got tired of trying to make them work...
      I thought I had a pic of both sides but only found one of the pass side.
      If you drag these, your headers are the last thing you'll need to worry about.
      Doug Gulley
      May 2010
      Orange, CA
      Here is what our Patriot ones look like
      Auburn, CA
      I too have run the headman and thought they were great and without issue. After running 2 sets of Patriot headers (BBC and SBC) I was not impressed with the quality or the fitment. They hit on frame and accessory locations that are standard no matter what engine / vehicle you used them in that they are listed for.
      Patriot is a cheap header with a coating to hide it. Sorry.
      Tim Tracy
      May 2010
      Orange, CA
      Quote Originally Posted by TT302Z28 View Post
      Sorry you feel that way, but I will give you a little history. Ermie Immerso was a pioneer in this industry and began making headers back in the 1950's. He made the EIE (Ermie Immerso Enterprises) line, Thunderbird and private label headers for many of the brands that people rave about. He decided to retire about 11 years ago and PerTronix bought the company under the direction of Jim Hairston who had been the Director of Sales and Marketing for Hooker Headers for 27 years. The only change made to the line in the beginning was re naming it Patriot. They are still made in the same plant in Rancho Dominguez CA, using the same fixtures and many of the same people that have been there for many years. Over the past 10 years the line has been expanded with new models and fitments. The Patriot factory continues to build private label for Many of the name brands that you are familiar with as well.
      Since then PerTronix has also added the Original Doug's Headers, Defender Harley Headers, and JBA Exhaust brands to the company making them arguably the largest header manufacturer currently doing business.
      We get very few complaints about fit or finish with the Patriot brand, but it is our lower priced brand, positioned to complete in the market with the other value priced brands like Hedman, Sanderson, Hooker Comp etc. The Doug's Brand and JBA our are higher market brands that go head to head with upper market brands.
      Auburn, CA
      ok....I have bought over 25 sets of headers over the last 5 years for Camaros and Chevelles.
      The Patriot Chevelle headers I have installed today on a 1970 with a BBC are terrible. the Passenger side is fine, it's the drivers side that points too much towards the ground. This makes it a pain to use these headers when the vehicles ride height is altered. Also, the drivers side was not just close to the frame (with factory mounts) but had be modified by almost half an inch. The only reason we bought these headers again was because we thought maybe the issues we had in the past on a different car were due to aftermarket mounts.
      Since we have stopped putting these headers on and began using the comparable Headman mid length product. A little bit more money for the coated units but they have not had issues.
      I'm not trying to bash a product but I'm also not trying to sell one either.
      Tim Tracy
      Jul 2009
      Bear, DE
      I've got the patriot shorties on my car, only the slightest little ding for the power steering box but otherwise they are great, the hedmans were out of stock everywhere so i had to go with something else. My hooker supercomps only had about 2 inches of ground clearance before i dropped the car another inch and a half so i had to go to shorties
      Jason Nichols
      '72 Chevy Nova-The Blue Bomb https://www.pro-touring.com/showthre...972-Chevy-Nova
      Dec 2009
      knoxville, tn
      I'm in the same boat with my 69, except that I have a mechanical clutch linkage to work around. I would love to see a lower priced option since this sbc is just a fill in until I do the ls1 swap in a year or so. but, it looks like I may have to bite the bullet and buy a set of thorley tri-y's for now.
      Tom Hensley
      69 ss/rs clone
      98 ta ragtop
      "attack life....it's going to kill you anyway."
      Atlanta GA
      hey guys..
      i ended up with a set of Patriot midlength headers..
      no clearance problems anymore.. BUT.. it kinda feels alittle more constricted.. slight change in the power i think.
      just installed these on The Nova. Fit great and are better quallity than the Hedmans they replaced. Hedmans had to be dinged to hell to fit.. But they have served me for 14 years so Im not complaining to much. BTW mine came coated and for only $100 off the Summit racing clearance rack..lol
      Quote Originally Posted by DynoDon View Post
