    Results 1 to 20 of 22
      Oct 2007
      Who makes/sells a front drive system
      With brackets only..
      Senario.. ls2 dropout from a GTO... 67 camaro...
      Have Vintage air polished compressor... wouldn't mind avoiding the frame notching and move the compressor up.
      So I was thinking just by a new setup
      67 Camaro In progress
      Mountain Springs, Texas
      How about this:
      http://www.kwikperf.com/
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Oct 2007
      that would work but its kinda ugly..
      Apr 2004
      OKC, OK
      We might be able to get one for you, but it will be Monday before i can give you an answer
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Aug 2003
      We have the Kwik brackets. Only one I know of that uses a 508 compressor. Everything else uses the SD7.
      May 2007
      Las Vegas
      Wegner...
      With Mezier electric water pump...
      Rich
      1969 Camaro (in hibernation)
      Aug 2003
      The Wegner uses a SD7 also.
      May 2007
      Las Vegas
      Quote Originally Posted by ProdigyCustoms View Post
      I thought since he has a VA compressor the Wegner would work.. I was thinking of emailing you about getting a quote for a VA Gen IV setup and Wegner kit...
      Rich
      Oct 2007
      well wouldn't the compressor I have be the SD7 since it came from Vintage air? I know the box says Sandeen on it?
      Can you get just the brackets for the Frontrunner system?
      Aug 2003
      Quote Originally Posted by MCMLXIX View Post
      In your case we would delete the A/C compressor from the VA order since the compressor is coming with the Wegner drive. Make a few other adjustments to the order, and it works out perfect and you do not end up paying double for a compressor.
      Aug 2003
      Quote Originally Posted by XLexusTech View Post
      The standard compressor from Vintage Air is a 508. The SD7 is a possible upgrade if it was requested when ordered. If you just bought the system would think VA or your dealer will exchange it for you.
      Oct 2007
      The Box says Sandeen SD5
      Perhaps someone from VA can help me the VA serial number is 0051161.
      I dont have a dealer I purchased this form another member here, they only used it for Moc Up.
      Also anyone know if the SD5 can be used with the OEM ls2 GTO bracket?
      bowling green,ky
      notch it get a sd7 compressor. then get a corvette accessory system w/ac. then get va adaptor for sd7 to that accy system. thats what i did and it works great. you can sell the corvette factory compressor. still alot cheaper than a vintage air serp or others, although i would rather have one.
      Aug 2003
      There is a SD5 adapter but it forces you into a huge frame notch. Get a quick bracket for it and learn to love it!
      Hifi, I am not aware of a SD7 adapter to a factory bracket. How makes that?
      bowling green,ky
      vintage air makes a bracket($90 bucks, rip off) that lets a sd508 (i stand corrected, sorry) mount where the factory corvette acc compressor does. plus, it runs off of its own belt.
      Oct 2007
      Quote Originally Posted by hifi875 View Post
      Looks like a good option but I dont follow how the belt would work.. you mention its own belt but.. not sure how that would go
      bowling green,ky
      the balancer on ls motors has 2 grove pulley. the back pulley is for ac.
      Aug 2003
      No worries HiFi. Reason I asked is my part request at the VA dealer meeting was for a SD7 adapter bracket. The 508 is REALLY big in that location and with some motor plates will interfere with the motor mounts.
      bowling green,ky
      mine fits fine. i am running the brp setup. i have run 500 miles or so with no problems a/c does really well. and it is a tight fit, but i have no vibration or rubbing issues
      Oct 2007
      VA part number is 141804-MCA
      Also HIF what engine mount's, frame mount and engine plates are you using? I have the ATS plates which may make this a bigger problem
