    Results 1 to 9 of 9
      Eastern Virginia
      Cleaning fuel injectors?
      Where do you guys have your fuel injectors checked/cleaned? I bought a set of 30# ones a while back & something is wrong with at least one of them. Need to have them checked.
      Scot
      Scot
      86 Monte SS
      Jun 2005
      Lynnwood Wa.
      Witch Hunter. But they are here in the Seattle area.
      http://www.witchhunter.com/
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      Indianapolis, IN
      Hey Scott, there is a place on Gasoline Alley but iI can not remember the name right now.
      Mike Norris
      Eastern Virginia
      Quote Originally Posted by Mike Norris View Post
      This guy is in Speedway:
      fuel injection DIVISION
      1330 MAIN STREET
      SPEEDWAY, INDIANA 46224
      317-487-9460 Office
      Scot
      86 Monte SS
      Texas
      I've wondered about this also - no easy way to do it in the home shop?
      -Bob (66 Nova)
      Indianapolis, IN
      Same place Scott, they just moved from Gasoline Alley not too long ago.
      Mike Norris
      Mike Norris
      Feb 2008
      Sesser, Il
      Scot I did a search on this and found where a guy made his own setup. Basically used a 9v transistor battery to open the injector and used pressurized cleaner to clean them. Same guy also sold the little filter and o-rings to replace afterwards. Cost about $25. If I find it, I'll send the link.
      Found it. http://fordfuelinjection.com/?p=82
      and another http://www.pelicanparts.com/techarti...ctor_clean.htm
      http://www.rowand.net/Shop/Tech/DIYF...orCleaning.htm
      Here's the one that used the 9v battery http://specthismiata.com/2008/06/15/...aning-at-home/
      This one has an attached YouTube video http://www.watkinsmotorsports.com/ho..._injector.aspx
      http://www.youtube.com/watch?v=VFJlTfHyrUk
      Doug Gulley
      Jun 2010
      Right on! thats the info I have been looking for
      I have had great luck with the procedure in the first link. Done it several times and it works great.
      I am going to try and build my on test stand to measure flow.
      Tom
