      Oct 2005
      Middleton, Idaho
      Leaking Head Studs
      OK Guys
      As the title states, I've got some head studs that are leaking as the system develops pressure. No leaks when cool with no pressure in the system. Does anyone have any suggestions as to a fix without pulling the heads and resealing each stud?
      Any input would be greatly appreciated.
      Steve Spoor
      Middleton, Idaho
      69 Rally Sport w/T-56, Quadra-Link, Wayne Due C-4 Clip, 420 SB2.2
      67 Chevelle, Art Morrison Chassis, 416 LS3, Inglese 8-Stack Injection
      2014 Ext. Cab Silverado, Lowered.
      europe
      no need to pull the heads. just do one at a time. pull it, reseal the threads and re-torque. i had the same problem on my BBC. went through one at a time and no more leaks...
      Jeff J. aka JJ
      1969 Camaro
      1952 Chevy Truck
      wir müssen Leben bis wir Sterben...
      May 2002
      Northern California
      pipe sealer works better than RTV. You guys run your studs finger tight?
      Vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Rustburg, Virginia
      I don't know if this is the correct way to seal or not, but I've had good luck using that brown sticky Indian Head gasket sealer goop on the threads.
      Newbury Park, CA
      I've had mixed results with teflon thread sealant. I've never had a problem with Permatex #2.
      Oct 2005
      Middleton, Idaho
      Thanks for the comments. The issue is these are SB2.2 heads and I can't get to the stud unless I pull the head. I saw on another thread about using Alumaseal. I think I will try that first.
      Would still appreciate any comments.
      Steve Spoor
      Middleton, Idaho
      Phoenix
      I have never had a leak with Permatex Hi Perf Thread Sealant (item # 56521) and their Surface Prep primer for anaerobics. (item # 765-1154).
      Wouldn't use Alumaseal at any time personally.
      Erik
      https://www.pro-touring.com/showthre...without-a-name
      Camaro LS2, T56, 12 bolt, C6 Z06 brakes, Rushforth Super Spokes, ATS Spindles
      2006 Chevy Trailblazer SS
      Apr 2008
      Newark, OH, / Concord, NC
      Quote Originally Posted by ErikLS2 View Post
      Do it right and pull the heads, the permatex products mentioned work great and for anyone else considering studs ARP makes studs that can be installed or removed with an Allen wrench, don't tighten the studs into the block just run them down snug.
      Dale
      IF COMMON SENSE WAS COMMON EVERYBODY WOULD HAVE IT
