Results 1 to 10 of 10
Thread: Pontiac 400 Engine - Intakes?
I'm not an Edelbrock carb fan. I'm also not a dual quad fan for close to stock pontiac street motors. But, the carb and intake will absolutely depend on the cam, heads, compression in addition to car weight and tranny. A dual plane will help with low end tq and may be where you want to be. It also depends on what you want to do with the car. Personally, I'd really want to know what cam is in the motor. Good weekend job! Of course, if you're just trying to solve the hot start issue, the recommendation to use a phenolic spacer might be a place to start. You'll just have to determine for yourself if you've got enough hood clearance.
'66 GTO Vert Project "Red Ink", 462ci of stroked pontiac power, TKO600, SC&C Stg II+, Tubular lowers, Currectrac Rear suspension, Moser 12bolt w/Truetrack, Wilwood Master and discs all around, too much fun for words...
