      Feb 2008
      Maine
      Mounting QA1 adjustable coil shocks
      I purchased a set of used front QA1 adjustable coil shocks from a member on here so I do not have any directions. Do these mount the same as any shock or do they mount on the top of the lower A arm? The hole in my stock A arm is not large enough for the shock to go up through so I mounted it on top. The car now sits about an inch higher than it did stock which is not what I was looking for. I was told they were for a 67 small block and would give me about 2" of drop. I have the coils adjustments as low as they can go and the coil is seated properly in the top seat. Do I need to modify my A arm to allow the shock to be mounted to the bottom?
