    Results 1 to 18 of 18
      Jul 2007
      Northern Virginia
      Frame sandblasted with playsand.
      I sandblasted my Impala frame with "playsand". What is the recommendation for final cleanup prior to applying epoxy primer that I purchased from Southern Polyuretane?
      Ray
      1996 Impala SS aka MistreSS (7800 original miles)
      LPE LT4 Heads/Intake
      Powerdyne Supercharger\T-56 Conversion
      MistreSS Updates: https://www.pro-touring.com/showthre...light=mistress
      Mountain Springs, Texas
      I went over mine a couple of times with wax and grease remover before shooting it. Don't wait too long or it's going to flash rust on you.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jan 2009
      Jacksonville Florida
      Just blow it off and shoot epoxy, don't use anything to wipe,you can't get metal any cleaner after blasting
      Do what's right,not what's easy
      69 Firebird
      71 Cuda
      98 Supra 6speed white APU
      98 Lexus GS400tt widebody
      Elite Custom Body
      Stefan B.
      Chicago
      You need to be really carefull what you sandblast with. Silica is a killer.I'm not sure if the sand your using is ok or not but you should definitely look into dedicated sandblasting abrasives for any future work. I'm pretty sure you do not want to use playsand. Someone please correct me if I'm wrong
      Tony L
      Aug 2006
      Belforest, AL
      Quote Originally Posted by 70 Chevelle View Post
      99.9% of sand that is sold at any home improvement store is Silica based. There are a very few companies who sell limestone sand, which is mostly safe, though I'd recommend at least a respirator.
      If you don't care about dust clouds forming when you blast, many home improvement stores carry pulverized limestone, which is a calcium powder. Great for blasting panels, as it's a lot gentler than other sands/abrasives.
      Todd S.
      "I like to race school buses..."
      toledo ohio
      go to spi website and ask Barry the owner of spi or call him
      dayton, oh
      yep. just wax & grease remover, especially any place touched by human hands.
      dave.t
      74 Javelin AMX - stocker
      Greenwood, SC
      I hope you did wear a respirator.... silica is nasty stuff when inhaled
      JC Scott
      Jul 2007
      Northern Virginia
      Talked to Barry and he says to wipe the frame down with their Waterborne Wax & Grease Remover. Thanks for all the info..
      Ray
      Oct 2009
      columbus, ohio
      Quote Originally Posted by SSTuner View Post
      how did your fame turn out after sandblasting with playsand? do you have any pictures?
      Rustburg, Virginia
      I hate sandblasting in the open....that crap gets everywhere....need ear plugs, respirator, goggles, ful face shield, and long cuff gloves as a minimum....and all that garb gets hot in the Summer, and then you drip salty sweat on your newly blasted material.....LOL....did I mention that it gets everywhere and that I hate sand blasting?
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by elitecustombody View Post
      X2 could not agree more
      David Sloan
      May 2010
      Athens, Ga
      There is always dust to remove after sandblasting. For sandblasting to work properly the sand particle has to disintegrate, which leaves dust.
      I wipe almost everything metal with naphthaline. Just keep it away from plastic or paint you don't want gone.
      Zach Daniel
      1970 Pontiac Firebird work in progress
      Jan 2009
      Quote Originally Posted by 70fireturd View Post
      what makes you think you can just wipe dust off sandblasted metal? it's blasted with sand, not nutshells ,some plastic media or soda, so the surface is very rough,it'll catch lint ,which will be impossible to remove,also by getting it damp and trying to wipe off, you're actually pushing the dust in micro pits leaving residue and opening window for problems down the road, that's why I advised to blow any remaining dust off, use a clean fine but firm bristle brush while blowing
      Stefan
      69 Firebird
      71 Cuda
      Elite Custom Body
      Stefan B.
      Aug 2006
      Belforest, AL
      The sand particle doesn't need to disintegrate for sandblasting to work. Granted, it often does, which causes dust. But that's not how it works.
      Todd S.
      Feb 2003
      St. Louis, Missouri
      I'd also say wipe it down with a dry rag while blowing it off. No reason to use a solvent...unless you've touched it. My blaster won't let play (river) sand through it...gotta use fine silica. What blaster are you using?
      Rick Butterfield
      Jan 2009
      Use a brush with fine but firm bristles, rags will leave lint
      L.A, Ca.
      After blasting, I wipe it down with Phosphoric acid, rinse, and blow dry.
      After that, I use a tack cloth to remove any residue and blow it off while it's suspended in it's final painting position. Then it's ready for epoxy prime & paint.
      John
      Camaro Purgatory
