    Results 1 to 14 of 14
      San Diego
      Coil behind firewall
      Has anyone installed their coil behind the firewall with a pass thru to distributor? If so, did you experience any downside issues?
      Aug 2008
      Pgh, PA
      I have. I mounted the coil using vibration resistance mounts (rubber) to the cowl (wiper linkage area) in my '66 GTO. I used the MSD bulkhead pass-thru on the firewall, and made 2 coil wires. One from the coil to the bulkhead and one from the engine side of the bulkhead to the distributor. I haven't run the car that much yet, but both in practical experience as well as having talked to MSD - no issues whatsoever. My ignition is already in my glove box, which makes it even easier.
      San Diego
      Excellent. Thanks for the feedback.
      Florida
      I had it that way in my 67 Nova David, no problems
      Sep 2007
      Montgomery, Tx
      I did all all igniton components bolted to a single panel
      behind glove box door on my last 2nd gen Camaro.
      It worked fine.
      Gary Rys
      69 Camaro
      Did anyone have trouble with a stereo installed? I would think that ignition noise would be an issue.
      John
      Aug 2008
      Pgh, PA
      Quote Originally Posted by 79ZED View Post
      John
      Stereo? In my car, I don't think you could tell. You can't hear the stereo with the car running anyway
      Seriously, it could be an issue. I'm running shielded cabling from the MSD 6AL2 to the distributor. I'm also using a Secret Audio mounted in the back of the car. So, can't tell from my perspective.
      Chicago
      I have my Msd box and coil mounted mounted behind the glove box also. Anytime you can keep your ignition box and coil cool thats a good thing.
      San Diego
      Do you have a stereo, nav equipment or electronic gauges mounted in the dash? If so, does your coil cause any interference with this equipment?
      Aug 2008
      Pgh, PA
      I have all Autometer electric gauges in the dash. Zero issues from the coil or ignition.
      Feb 2007
      USA, TN
      Quote Originally Posted by wmhjr View Post
      Which plug wires are your running? My Autometer speedo is going nuts over what I believe is ignition interference.
      Aug 2008
      Pgh, PA
      Quote Originally Posted by TnBlkC230WZ View Post
      MSD 8.5mm super conductor #31189
      Feb 2007
      USA, TN
      Thanks, they are on my short list.
      Feb 2006
      Spring Texas
      Ive had mine under the dash for 15 years with no problems.
      Mike
      69 camaro, 502 w/8-71 blower, street car
      http://s268.photobucket.com/home/pro...69camaro/index
