      Feb 2008
      Sesser, Il
      Lakewood Bellhousing Setup
      I've got a Lakewood bellhousing setup for a mechanical linkage.
      1. What is the proper way to adjust the clutch fork ball? I'm not exactly clear on what to look for/at when adjusting it in and out.
      2. I may go with a hydraulic throwout bearing in the future. I was told there is a measurement needed before ordering one. I'd like to measure this now before everything is in the car so if I do decide to get one I won't have to pull everything apart, measure, and then wait for it to get here. This will be a daily driver once it gets running and I can't have much down time. What do I need to measure? Is it the distance from the bell face to the pressure plate springs?
      Doug Gulley
      Rockford Illinois
      The lakewood instructions should have a measurement for you, if not you install the fork on the bearing and turn the ball in until the fork is past 90 degrees and just a bit more forward to the bearing when the bearing is all the way forward to the pressure plate. This should give you optimum leverage and more than enough throw.
      Yes that is the correct place to measure and then you put the shims on the trans along with the throwout bearing and make it the same distance. The throwout bearings come with all the shims and directions anyway but you are on the right track.
      I love my Howe hydraulic throwout bearing, the new style they have now works very well. To bleed it I just open the bleeder and pump it slowly 2 times and then let it start to drip freely into a container and it will turn into a steady stream after about a minute or 2 when it is finally bled right. You just keep filling the reseviour until it gets there, you will see at times it slows up and then flows more and speeds up, the slow times is when the air is escaping. the pedal will be real good when you do it right.
      I would never go back to a linkage again.
      Feb 2008
      Sesser, Il
      Thanks Jim. I may just try and go that route.
      What master do they recommend with their throwout? I have an LT1 style unit, will that work?
      Doug Gulley
      Rockford Illinois
      Quote Originally Posted by 86Cutlass383SR View Post
      You have to have a 3/4 in. master, I use the Wilwood brand. You can call Howe and ask them, they have a great tech group and were some of the nicest understanding people to work with.
      There is a thread that Andrew made that has all the info you need on how to do the install and make sure you have the right amount of throw for the volume of the setup. You may be able to use the one you have but you have to check it first to be sure.
      Good luck and follow the thread all the way and don't take any shortcuts or you will be pulling it apart and that is no fun.
