Thread: t5 help
05-14-2010 #1
t5 help
hi guys, i have a friend who is giving me a t5 tranny that is in good shape. i was wondering if it would fit in a 69 camaro with a chevy 350. what would i need to complete the install?
05-14-2010 #2A T5 had the same bellhousing pattern as a Muncie so it will bolts right up to the bell. The T5 has a 17* tilt to it so the shifter will sit at an angle. The shifter will also sit farther back than a 4 speed will. The clutch is a 26 spline and the Muncie (except for an M22) is a 10 spline. The output is the same so a 4 speed or TH350 dirveshaft will fit the output. The driveshaft will need shortened. Some T5's have the cable output and some have the electric output but they are interchangable.
Doug Gulley
05-15-2010 #3
- Aug 2004
- cookeville, tennessee
- 117
