Results 21 to 40 of 43
Thread: Awd ?????
05-15-2010 #21
- Aug 2004
- Atlanta, GA
- 296
I'd be looking for Holden Message boards, it looks like they have offered AWD with LS engines down under.
http://www.youtube.com/watch?v=uD-jG4tVTDo
I understand C5/C6 use the same knuckles front and rear but not have read of anyone using the rear bearings on the front in an AWD build.
Lamar
00 C5 hardtop H&C 436 rwhp with an 04 Z06 Suspension
70 Chevelle SS396
05-15-2010 #22
Actually with the Skyline stuff i can disconnect the front diff To do burn outs......... That was one of the major things i looked at ..Im not sure how to do it but there are 100 video's of guys doing burnouts then launching them in awd... if i end up going this route ill end up using all the front suspension tranny t case etc form the Skyline and putting it to the lsx.. there have been a few successful swaps of v8's into the skylines and there is a guy in Canada that is putting a ls1 into one now.. a few guys have done the Nissan titan engines into them and some toyota engine's
One kinda cool thing is the ls engine actually are smaller than the inline 6 that came in the skyline..and about 60lbs lighter.
I am really supprissed how inexpensive this stuff is i found a complete front half of a car engine and all for $1200 bucks..its the smaller engine but i believe they use the same components..
Tons and tons of thought will go into this as i haven't even got the car back yet.. 4th of July weekend she be coming home all 1200 miles of it yay!! to daddy again to be rapped and pillaged and cut to flipping pieces..YAY!!!!!! i found my first car now time to cut the crap outta it!!!! But this time with more than a pair of tin snips like when i was 16...........
Just love the stuff..........
05-15-2010 #23YAY!!!!!! i found my first car now time to cut the crap outta it!!!! But this time with more than a pair of tin snips like when i was 16...........
05-19-2010 #24
Starting The Transformation
- Nov 2006
- 264
That's rubbish.
The dodge stealth/GTO/3000GT or whatever you want to call it makes excellent use of the 4WD system. It handles on the merit of a good setup....I've been assured it's not active.
My A6 Quattro just has Torsen Diffs, it's not electronic either.
Setting up a 4wd car is no different to any other. Try it in anger, adjust, try again. It's still spring rates, anti-roll bars and geometry. And lots of reading in the suspenstion section of this forum. lol'79 Trans Am W72 400/4spd Y84 S/E with WS6 T-Tops LSD AC OK?
Remember, big engines are for those trying to compensate for something.
05-19-2010 #25
- Nov 2006
- 264
Don't believe everything you hear about skylines. I've had one with a dead tranny on my drive.
On the older types, the rear diffs are what control the bias. They have an oil pump on the diffs that engages/disengages the front bias depending on the flow from that pump to the transfer box. It's fundamentally a very simple system. The later ones used abs sensors and need the ECUs to monitor wheel speeds etc....they're very similar to most other modern 4wd systems including the Ford Explorer.
I couldn't have nissan parts on my car though. Something about Nissan after being up close with skylines...they're just not solid.
Incidentally, I'd quite like to use the explorer running gear on a muscle car. I think it'd work quite well. It didn't look too big under there, it's obviously very strong and plentiful. The front suspension is no good for a car, but the axle will be and the back end is very muscle car friendly indeed.
PS, audi stuff is useless. There's a reason Audi's don't handle and that's because the 4wd arrangement just isn't a good one. Engine is far too far forward.'79 Trans Am W72 400/4spd Y84 S/E with WS6 T-Tops LSD AC OK?
05-19-2010 #26
- Mar 2010
- AZ
- 801
