      Melbourne, FL
      Trunk weatherstrip channel replacement??
      I'm getting ready to use the three piece trunk gutter/weatherstrip channel kit to fix my trunk in my 67 'Bird vert. Has anyone ever used this? What tips can you give me before I attempt this repair???
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Rockford Illinois
      Make blocks for spacing and then use lots of clamps before you weld them. Drill holes and plug weld them to make it easier.
