    Results 1 to 20 of 32
      Jan 2010
      Delaware
      Oil Accumulator question....
      Ok, before I start just a quick note.....this isnt the "do you think I need an oil accumulator" question...lol.
      Since I hope to eventually do a bit of road racing, and also for extra insurance on start ups I am considering the addition of a 3 qt oil accumulator.
      My question is about the specifics of where that 3 qts of oil resides at all times. Moroso's instruction sheet basically says that after initially charging to 100 psi to move the piston all the down you bleed it to 6 psi, add the additional 3 qts to the pan and then start the engine.
      However, my understanding of how it works makes me wonder if my engine at idle and 15psi oil pressure is only going to partially fill this 3 qt reservoir.....basically leaving excess oil (1 qt?, 2 qt?) in my oil pan? That 6 psi in the accumulator will climb as oil is forced into it, so while it might be full once oil pressure reaches a certain rpm......
      From what I've noticed I'm at about 15 psi at idle, 35-40 psi at 1800 rpm, and a full 70 psi (the oil pump has been shimmed for a little extra pressure) at anything over around 2200 rpm.
      Any thoughts on this?
      Thanks!
      P.S. - The engine is a 462 ci Pontiac with a 77mm Garret T6 turbo, or as I tell people a 455 powered Dyson type vacuum cleaner....that filter is where I attach the hose.
      Henderson,NV
      I run a 3 qt Moroso unit and it takes just shy of 3 quarts. I leave mine off unless I'm on the road course. Once in a while I'll turn it on just to mix the oil. 15psi will overcome 6 psi. It's simple to check. While idling at 15 psi, close the valve and shut off the engine. Check your oil level.
      Todd
      Jan 2010
      Delaware
      Vegas,
      Unfortunately I cant check yet as I havent purchased it...hence the question...lol. I'm guessing you have though. Do you operate yours manually? Did you make your own lever system?
      Apr 2008
      Newark, OH, / Concord, NC
      Quote Originally Posted by Vegas69 View Post
      Ditto
      Dale
      IF COMMON SENSE WAS COMMON EVERYBODY WOULD HAVE IT
      Henderson,NV
      Quote Originally Posted by aronhk_md View Post
      Vegas,
      I do operate it manually and moroso sends the manual valve with the accumulator.
      Todd
      Jan 2010
      Delaware
      Thanks guys.....another question then. If 15 psi will move the entire 3 qts into the accumulator, why do you run it turned off most of the time except for track use? Why not just leave it on while the motor is running?
      Also, Moroso's instructions dont make a lot of sense to me. Basically on initial startup they are saying add the extra 3 qts into your oil pan.....but it would seem to me on that first startup your engine bearings are going to be starved while the oil pump fills the accumulator.
      Henderson,NV
      That is exactly why I leave mine off except during road racing. When you start the engine with the valve open, it does take longer to build oil pressure. I normally open the valve slowly with the engine running. On the flip side, flushing the bearings when the engine hasn't been started in sometime is probably beneficial.
      Todd
      Jan 2002
      Italy
      I havent installed mine yet but I plan to use a "choke" cable to activate the valve from the inside of the car.
      Have Fun!
      André
      2009 Chrysler 300C Touring.
      3.0 liter V6 diesel, five speed auto, black with light grey leather.
      1968 Chevelle Coupe.
      355cid, Viper T56, Corvette C4 IRS (Dana 44) and Corvette C4 IFS with Porsche 6piston Brembo's.
      1980 Chevy Van (shortie G10).
      355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
      2000 BMW 540i Wagon. (FOR SALE €7K)
      4.4 liter V8, six speed manual, lowered and with Bilstein B8's, silver with black leather.
      2001 Ford Focus Wagon.
      1.8 liter turbo diesel, and a whoppin 90HP.:bsjerk:
      1968 Benelli Motorella
      foldable 50c scooter to go in a car trunk.
      2x '90s Yamaha TZR 2stroke bikes.
      one 125cc one cylinder and one will be 350cc two cylinder.
      Jan 2010
      Delaware
      That was one idea I had too tiger...depends where in the end I decide to mount it though.
      I run the 3 Qt system as well with a 35 psi electric valve. It will charge to the max oil presser the motor reaches and hold it until the oil presser dips bellow the 35 PSI. Then it will push oil until the two equalize. I turn mine on and off by a electric switch in the car. I turn it off on the street as well so when the car drops to a idle it does not over fill the pan. I also have a pro light in my hood so I know when it is discharging, It comes on more places than I like at the track but is saving the motor. Hope this helps Randy
      Please see my PT Garage for more info on ProBell Camaro. 67 style,99 comfort, options and drive-ability with NASCAR Late Model suspension front and rear.https://www.pro-touring.com/forum/vb...?do=view&g=106
      Car Domain PG
      http://www.cardomain.com/ride/2565383
      Jan 2010
      Delaware
      ProBell......where did you get the electric valve & switches?
      Dec 2007
      Wisconsin
      Canton makes such a switch.
      Jan 2010
      Delaware
      Thanks cmraman. I called Moroso, and their tech told me that even at 15 psi idle the 3 qt cannister should be full and normal oil level in the pan. Not sure I believe that......
      Henderson,NV
      Even if there is a little extra oil in the pan at idle, that's the best time to have excess oil. Once you take off the accumulator will be full. You are over thinking this deal and that's saying alot coming from me!
      Todd
      Jan 2010
      Delaware
      LOL.....I tend to over think things when I have the luxury to do so because I've bought stuff in the past only to find out later I should have researched better. But in this case I just went ahead and purchased a nice used Moroso 3 Qt accumulator with mounting brackets for $96 shipped. I'm happy with that deal.
      Just need to decide where to put it now. Between the turbo, piping, intercooler, wastegate, trans cooler, fuel regulator, March serpentine system with A/C compressor, condenser, power steering reservoir.......I'm sitting here scratching my head.
      But I'll make it fit even if I have to use my favorite tool! (hammer).
      Thanks for your help guys.
      Jan 2002
      Italy
      I'll mount it hidden in the left inner fender, waiting for the brackets and fittings as we speak.
      Have Fun!
      André
      Henderson,NV
      It's tought to fit that big honker anywhere decent. I put mine on the inner fender but my car has the street fighter look so it works. I know a friend of mine is installing his in the trunk with a bulkhead. That's a long run but should be fine.
      Todd
      Rustburg, Virginia
      Canton electric switch:(choose by pressure)
      http://www.summitracing.com/search/B.../?autoview=SKU
      Canton's 3qt. accumulator:
      http://www.summitracing.com/parts/CTR-24-016/
      Jun 2006
      NW burbs IL
      Quote Originally Posted by ProBell View Post
      Randy I have my cooler and accusump up and running. Why would you turn it off on the street? I dont see what the downfall would be.
      Matt
      Jan 2010
      Delaware
      I'm going to run mine on the street. Only downfall I believe is in that initial filling stage on install when it is completely empty. After some research I am going to wait to open it until AFTER the initial start with the unit on....then I can crack it open slowly to fill. As a routine then for starting I'm going to open it and hit the starter in 3 seconds. It should pre-pressurize the bearings with oil, but not completely empty and therefore not steal oil pressure after the start.
      As for mounting....I'm going to try and see if I can find a spot to frame mount it. Don't really want to have a long oil line run.....I want it close to the motor. Going to skip the pressure switch for now. Realized that oil pressure gauge was a little off and its actually idling at 19-20 psi, which is better. I'm also going to do a test once installed....going to run it with the oil pump at its full 70 psi, then shut the valve off, unhook the line and measure how much oil it ACTUALLY holds when the motor is under load and the accumulator is set at 6 psi. Just to satisfy my own insanity.....I want to verify that I'm not running an extra qt in my sump while at speed.
      1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
