    Thread: LS2 Vats ?
      May 2008
      Chicago
      LS2 Vats ?
      Will a LS2 with the VATS not deactivated have spark to the motor or not. I am trying to start the car and was wondering if the car will start and run for a few seconds then die. Can you spray carb cleaner to see if it will fire? I still haven't had the computer programmed yet. I wanted to see if I have everything wired correctly first.
      Thanks.
      Morehead City, NC
      Quote Originally Posted by kochevy67 View Post
      Thanks.
      I do not think the VATS will allow ignition unless all sensors are present and you are using the factory ignition switch. Call John at Speartech for an educated answer. 765-378-4908
      Mike
      May 2008
      Chicago
      Had the ECM flashed and it is up and running. Hell yeah.
