Thread: Hard line flaring 5/8?
So heres my problem
I am redoing the fuel system on my Syclone. I will be running a sumped tank, a1000 pump, aeromotive pre/post filters, aeromotive reg after second filter short return line, to a y-block to each rail with a crossover line to each rail.
I am going to rip out all the crappy braided line thanks to what I have heard about it on hear along with a bad experience with it. I planned on replacing it with the teflon lined hose till I saw how extremely expensive it was so now I think the plan is to use stainless hard line with teflon lined short hoses at the tank and engine.
My problem I have is I have -8 and -10 lines. -10 from tank to pump to y-block with-8 to each rail.
I planned on just buying the mastercool kit with the 37 degree flare add on kit. I can justify the cost of the tool because it wouldn't be a one time use tool you know. I then read that the tool only goes to 1/2.
How are you guys flaring hard line in 5/8? I was planning on getting the aluminum line from mcmaster carr but I found stainless hard line for $3 a ft locally and I can get it in ten ft sections which should be perfect for my truck. It is 304 fully annealed in .035 wall which from what I have read is whats recommended right?
I have found some 37 degree flaring tools in the $130 range but that would make it a one time use tool. I don't like the idea of using those hard line adaptor fittings because I don't trust them for high pressure.
Here is the specs on the truck '91 gmc syclone, 4.3 v6 built engine, t-72 single turbo, 75# injectors, base fuel pressure roughly 50# possibly running up to 30 psi boost, a similar build made 600hp and 800 tq
http://www.syty.net/forums/showthread.php?t=64336
I do plan on making more power later on too
Thanks for all the help!David Van Hulst
'91 GMC Syclone #892
'92 GMC Sonoma GT #516 Daily
'92 GMC Typhoon #0076 Dads
http://community.webshots.com/user/syclone892
