      Oct 2007
      Low cost wheels for a mini tub camaro... Options?
      Looking for an inexpesive but nice option... think i might of found an option but I dont know what backspace..
      Detials.. 67 camaro Mini Tubs.. Oem subframe with spc arms and ATS coil over conversion.
      I al looking at these http://www.newstalgiawheel.com/wheel...ubcat3=1011109
      18 x 9.5 rear backspace..? Not a big lip fan.. like symaitry instead
      17X 8 or 17x9.5 front? on oem frame... backspace?
      I am open on tires but want the tires to tuck under the lip
      67 Camaro In progress
      Dallas TX
      If you are mini-tubbing why not 11" rears? Also if you are willing to spend that much Intro's are not much more
      Oct 2007
      Well I guess I should explain a few things... I am only mini tubbing because my shock towers and inner wheel wells were shot.
      I really don't like the look of those big lipped almost pro street wheel tire combos that are populat on PT camaros
      I do like the nastalgia road racing look.
      Also I am going to be using a Protigy Bar / G link so I have the option of a longer housing as well.. its a bit or a science project but will be a bit differient the most.
      So what i was looking at is those Cobra Rims which are only offered in 9,5 which I think will be pretty good. I may be able to get the low under the lip look I am looking for which is tougher on the 67/8 then on the 9
      And I think 17 limits your tire options..?
      Vintage wheel works 17x8 and 11.
      Nathan Shaw
      71 Nova, 1000+whp 5.3, 8 second autoXer.
      Oct 2007
      Quote Originally Posted by LS1NOVA View Post
      Backspacing? tire suggestions? based on my goals?
