    Results 21 to 40 of 57
    1. #21
      Mar 2010
      Central IL
      A ground will not cause an over current condition a bad ground would cause an under voltage/current situation.
      Sean
      The difference between stupidity and genius.... genius has limits
    2. #22
      Sep 2007
      Denver
      unless its a hot wire grounding.
      David Beckstrom DVM
    3. #23
      Mar 2010
      Central IL
      Quote Originally Posted by Denvervet View Post
      That is called a short (to ground) so it's not applicable.
      Sean
    4. #24
      Rockford Illinois
      Quote Originally Posted by DC454 View Post
      You really can't have too many grounds. Try moving move the main ground to one of the starter bolts and add a ground strap from the back of the head to the firewall. Is the chassis, body and engine all grounded? Is the DFI box also grounded?
      My system is grounded very well in all parts of the system, the ignition not only goes to the block but the same point it is attached is the 2-0 welding cable that goes to the battery.
      This problem is in the ignition box or the ecu from what I can tell. I would guess that the 6A box is causing the over current code. By how much it is giving too much cuurent is a mystery right now but it must be more than .25 amps. All the other systems go to .5 amps before the code shuts it off.
      I can go in and remove the code and see what happens? It may burn up the ecu somewhere or it may not? I do know that it is going to have to go back for a check up if I can't find a solution..
      The simple stuff has been drilled in my head over the last year dealing with this and what ever it is will have to show up sometime as a total failure, until then it keeps starting and dying when ever it wants to think it is over the parameters.
      Thanks for the thoughts and if we were starting back a year ago the grounds may have been an issue. Right now it could be more of a short to something with more current to do an over current.
      We will see if I need a code 66 to keep it alive or it will die and get rebuilt.
    5. #25
      Rockford Illinois
      I just had a good long talk with Sean and tried to come up with something to go on for the problem. I thought I could disable the code from shutting it off but I am not able to do it.
      I tried a few more times and it starts but only runs for 10 -15 seconds.
      I am starting to lose my patience again with this system. Just when things were going good with it I run into this. There is no rhyme or reason for it. it just is. I keep thinking it is the 6A box that is bad now for some reason. It could have been cuased by the est not being disconnected but that is highly doubtful.
      I will have to see what I find out on Monday.
      I did get my oil leak fixed. The camera lied to me and it wasn't the weld that was leaking. When I got the car up in the air and could get in and see real well it was a pan bolt that was not in all the way because it got jambed up on the lock washer and seemed all the way in because it was bound against the pan. A new bolt and washer and it tightened up and stopped for now. It may need some sealant on it ? For some reason it must be open on the other side and can leak thruogh the threaded area.
      My laptop charger just bit the dust it seems and I only have about 35 minutes left on it before I have no laptop.
      I wish my luck would get better, I am getting tired of being stuck in the mode of getting it running. I had it running good and then Kablewy, had it up and running and then it dies. What next?
      I hope Accel has a better answer on Monday as to what to do. I would bet a lot of money that they would check it out and find nothing wrong.
      Still looking for the gremlin, the little creep.
      I am now going to drink a beer and see if it can alter my mind to jello and mello. Want to join me !!!
    6. #26
      Mar 2010
      Central IL
      Quote Originally Posted by Jim Nilsen View Post
      Already there I was having a beer while I was on the phone with you.
      Sean
    7. #27
      Rockford Illinois
      I have thought about this overnight and have come to the conculsion that the code is telling me exactly what is wrong.
      The ignition output driver is putting out too much current. Now where the output driver is has to be the big question. Is it in the ecu or is it in the 6A box? why would the ecu care if my ignition is putting out more current? Hotter ignition is always better ,right lol?
      When all of the other output drivers in the ecu are .5 amps before they shut off the ignition why is the ignition output half of that?
      I wish I had a schematic of the inside of the ecu to be able to find the driver itself. With that thought it makes the inclination that the ecu has the bad output driver.
      The sad thing is that when I talked to Accel they just said to look for a bad ground. This tells me that they have never experienced this code and solved the problem before and are just repeating the normal mantra for most all efi problems. Blaming a bad ground or low voltage is always the first thing to look for in efi and I have been through this long enough to know that I don't have low voltage or a bad ground ,leaving only a bad output driver as the code says. Why Accel doesn't understand their codes and how to resolve them is a sad situation. They should have told me they would look into with their tech people and get back to me. I feel like I have to teach them what to do everytime I call about something.
      I think I will do another google search for something somewhere another person has had the problem and possibly has the answer.
      I don't want to pull out the ecu again but it seems like it has to be tested. The 6A box seems to be working or the car wouldn't run at all.
      If you are an electrical engineer I could use some help.
    8. #28
      Rockford Illinois
      I tried a few more times today and have found it doesn't even want to run for more than a few seconds if it even starts up now. i think what ever was going bad has degraded enough to disable it almost altogether.
      We will see what Accel has to say tommorow? I will be drilling their minds to get a straight answer and will not take the normal matra of answers. They either know what it is or they will have to find out when I send it back to them.
      This is the last time I will ever try to get them to get it right, the next time it will be a new system of any kind and I will never recommend them for anything if they can't fix it.
      I just want to drive my car and have no problems with the accel part of it again.
      I have some things to do that require the car to be apart and now is the time to get them done from what I can see.
      I do hope I can get it running before the end of the month so I can go to the Midwest challenge if not I will be at the Motorstsate for sure even if I have to put in something different.
      THIS SUCKS
    9. #29
      Rockford Illinois
      I just got a straight answer about code 66 from my engine builder who talked to accel for me. It is either the coil and/or 6a box that is bad and it is sending too much amperage to tthe ecu and the ecu is shutting itself off to protect itself.
      I kept looking and trying to find the problem and cranking on it could have eventually damaged the ecu. I am hoping that the ecu is ok as I stopped when it didn't want to run longer than a few seconds.
      So there we have the correct answer for you all and i am going to go get a new box and coil and see what happens. If all goes well the car will run tonight or tommorow since it is a lot of work to rewire the 6a box in the car. I may make a plug connector to make it easier.
      The disappointing thing is that my 1st call to accel should have gotten me the answer I needed and I would have known what to look for and I could have had the new parts already.
      The good news is that the new parts are less money now than they were. If you look online at Jegs they want $264 Summit $164 and my builder around $120 so the price is so wide it makes you wonder. The other thing is that some of them are analog and some are digital so you have to look close to see which one you are getting.
      Wish me luck on the ECU being good still.
    10. #30
      Rustburg, Virginia
      Jim, I would....with the luck that I've had from those MSD boxes, a weather tight plug is the way to go.
      Should the box go bad, you just unplug the old and plug up the new.
      My last episode was a box that worked at lower and mid-range rpms, but the ignition would bust up as the revs climbed up above 3800 or so.....took me forever to figure out what was happening. I didn't look at the box initially because it was brand new, but after swapping it out the ignition cleared up.
    11. #31
      Mar 2010
      Central IL
      Jim,
      Good to here and hope they are correct on the cause for the sake of sanity.
      Quote Originally Posted by John Wright View Post
      Sounds like a bad rev limiter chip been there done that.
      Sean
    12. #32
      Morehead City, NC
      Jim, On the Thruster DFI install I did, we went thru 2 ign. boxes and 2 coils before we got our problems fixed. Have no clue why these parts were failing and neither did Accel. As of last week my customer has had no more troubles with the EFI. Wishing you the same outcome.
      Mike
    13. #33
      Rockford Illinois
      Quote Originally Posted by Mike Holleman View Post
      Mike
      Thanks Mike for letting us in on the problem and the solution you had to deal with. It is frustrating when you call the manufacture and you don't get the answers you need to do what is expected to solve the problem.
      I would be a week ahead and of fixing it and the frustration would have been eliminated to some degree. It is the unknown that frustrates me the most and when the answers don't do a thing it makes it worse.
      I am glad to know that your customer has had no problems since.
      See Ya
    14. #34
      Rockford Illinois
      Still not working
      I just got done installing the new Accel 6A box and the coil. The 6a box was taken off the engine on the dyno and it had worked with no problems, the coil was new and when I tested the resistance it was identical to the old one.
      I called the engine builder and he suggested that I go through all of my plug wires to make sure they were all seperated well because he has had several times that a plug wire has shut down his whole dyno. The new angle plug heads made my wires just a bit shorter on several but I have never seen any problems at night when you could see them arc across and I have never had any missing from them.
      So I started going through them and found nothing, so I decided to remove the cap and rotor and I found a most interesting problem. The rotor for some reason has become loose on the post, not just a little but a lot and it is somewhat black inside the hole that it mounts on. this is very strange to me and why this has happened is beyond me and it was not like it is now the last time I installed it, I did however think that the last time I put it on it seemed to go on easy but didn't think anything of it. Now you can rock it in all directions. I don't see where it has been touching any of the terminals on the cap or the end of the rotor but it could obviously be coming very close.
      So tommorow I will be putting on a new rotor and a new cap to see if it is the problem. The fact that it may have been getting close to being bad enough to cause problems at the same time as the engine went and then just being able to get the engine running long enough to get it broke in and keep getting progressively worse could be amazing timing. The engine runs good when it runs but it did seem to be different sounding at times from one fire up to the next but not enough to think it was anything but just breaking in and sounding a bit different, but now it may all make sense why it would start and run for a few seconds and then run for 20 minutes the next time since the rotor could have found a bit of a different position.
      Has anyone here ever had the same problem with a rotor doing this?
      It will be a miracle if it solves the problem but it could or it might just be a coincidence. If this was the problem I will have learned something new but that is a mystery as to how it wore loose. You can actually see the one area is thinner than the other 3 and 2 of the others are worn too. why it is black also makes me wonder?
      Here is a pick of both pieces.
    15. #35
      Sep 2007
      Denver
      It doesn't make sense the rotor would somehow be worn loose ..if it was seated completely on the shaft . In the top of the rotor that protruding "key" doesn't look worn and if it isn't then there shouldn't be any play, rotationally speaking. I don't think the dark dust is exciting. All that said I sure hope a new rotor fixes your problem...esp since I have a gen 7 to install soon and now very anxious about it being a royal PITA. Thanks for keeping us posted
      David Beckstrom DVM
    16. #36
      Rockford Illinois
      I got out the digital calipers and measured the space on the shaft and put it up against the rotor and found the slot to be about .050 or more on the wide side. If the rotor isn't tight on the circumference it will be able to go back and forth. Check your to see if it is the same? I am curious as to whether it is just my dual sync or if it is all of them , I am betting they are all the same. When I first got mine it was very hard to slide the rotor on. It sure is poor manufacturing if they are all that big compared to the rotors when it comes to the space.
      I too hope it is the problem and it will make a lot of others a bit more aware of the problem and probably a bit more nervous too. I will keep a spare in the car just in case, in fact I would almost want to keep the whole array of parts if I was to go a long ways away.
    17. #37
      Rustburg, Virginia
      That dark material inside the rotor button....is that bushing material? Is the dizzy shaft loose or does it still feel tight? Weird, none the less.
      Does the carbon button ride good and snug on the tab on the rotor button? Looks like there wasn't any arcing around or it would be dark around the carbon button inside the cap, so it must be OK. Did the carbon button leave a mark where it has been riding on the tab? Does it reflect the idea that your rotor button has been wobbling?
    18. #38
      Rockford Illinois
      The distributor shaft is still good like it should be, that rotor itself is as loose as a goose. Why it did what it did is a total mystery to me. never in my whole life have I seen this happen. At the rate it degraded and the way the code progressively got more frequent it is no wonder it would run from the beginning and get to the point it would start or just run for a few seconds.
      I am still wondering if anyone else has ever had this happen?
      The one good thing is it finally got bad enough to see it easily. now if the other good thing is that it will fix the problem with a new rotor.
    19. #39
      Mar 2010
      Central IL
      It very well could be the problem but how that would affect the DFI and set a code is a mystery to me. The secondary side of the coil is isolated from the the primary side, it works on inductance and has no effect on the current draw of the coil.
      Sean
    20. #40
      Rockford Illinois
      This is going to be a mystery that needs to be solved , that is certain.
      The rotor had no visible problems on the carbon button or the distributor tab. The tip of the rotor and the cap terminals do0n't have any real abnormal signs or wear or contact. There is however a few pits in the end of the rotor tab to the terminals were the spark would jump that are not on the leading edge like normal but they are not deep or very many. I will have to post up pics of the rotor from all the points of interest.
      I just hope that the rotor is a standard size and the Hot Rod shop has one in stock.
      It is possible that the oil pump shaft might be sending harmonic vibrations through the distributor causing this problem but why ? The problem may have started with the old engine that blew up and since the dizzy went into the new engine the problem came with it. The rotor obviously had to have been going bad to have degraded that fast.
      When the learning curve feels like a circle you are getting nowhere !!
