Results 1 to 13 of 13
05-06-2010 #1
A Favor From Those With 4link Software
I'm asking a small favor from those of you who have 4link software. I'm curious as to whether these packages can also handle a 4bar suspension. In other words, if the upper and lower links are parallel, do they give the right answer or do they "blow up."
Here's the input to try:
- 18 inch center of gravity height
- 100 inch wheelbase
- 16.935 inch upper and lower link lengths (yes, it's necessary to carry it out to the thousandths of an inch in order to force parallelism with the 100% antisquat line)
- 11 inch and 17 inch vertical to rear pivots
- 14 inch and 20 inch vertical to front pivots
If the software is able to handle 4bar suspensions, it will tell you that the antisquat is 100 percent and the instant center is an infinite distance forward and an infinite distance up.
Thanks for your time. Appreciate it.
http://www.racetec.cc/shope
