05-05-2010 #1
- Mar 2008
- 21
'68 Firebird Front Suspension Upgrades?
Hi all! I want to improve the front suspension but I don't have alot in the budget for upgrades right now and I don't have much knowledge on how to setup a cars suspension. I'd also like to keep the car at about a stock ride height or a little lower, I'm thinking less than a 2" drop in the front. Right now the front end is stock other than the disc brakes, it has rubber bushings and old 6 cyl springs. In the rear is a 9", CalTracs along with the split monos and shocks that were suggested by the guys at Calvert for a drag strip setup. The car was set up to go in a straight line and it did that well now I'd like to get it to handle the roads a little better. From what I've been reading, SC&C uppers, tall spindles, new springs, shocks and bushings would be the best way to go possibly. Of course I can't afford that right now, LOL.
So, I want to change what I can afford to right now and upgrade the rest at a later date. Since the disc brake setup isn't that old I plan on keeping it the same. I was also planning on keep in the stock A-arms and replacing the bushings with poly.
First question: can you use the tall upper ball joints with stock upper arms? If so that might be what I do. If not, I will do the G-mod.
Second question: Would offset shafts do me any good?
I was thinking of going with Global West S-41 springs. The are supposed to be Firebird specific. IIRC they are rated at 500 lbs and only drop the car 1". Would these work well for me?
For the rear I was planning on just keeping it as is for now.
Am I headed down the right path?
Any input would be appreciated!
Kevin
