    Thread: Band clamps?
      Feb 2010
      Band clamps?
      So i ordered a 2.5" Pypes exhaust for my gto and I'm planning on using the band clamps for the install. Should i use some type of sealant in addition to the clamps to prevent leaks? Thanks!
      BJ
      66 GTO LY6/4l80e
      Build Thread on LS1tech
      Aug 2001
      Wilton, CA. (Sacramento)
      no, they seal fine without sealer. Just have the clamp snug to the two machined pieces before you weld them to the pipes so the flanges match up straight.
      Jody
      Dec 2007
      Carlsbad, Ca
      i think jodys talking about v-band clamps. is this what you planned on using?
      Tim
      Build Thread Link
      Feb 2010
      I saw those for sale in summit, I ended up going with a clamp by walker that you don't end up welding, just get tight with the two bolts. For now these will be good enough. Hopefully they don't leak
      BJ
      66 GTO LY6/4l80e
      Aug 2005
      Hamilton, NJ
      The wide ones? I've used them. Only issues I had was if the joint is near a bend and the clamp needs to comform to a bend, which they will only do to a small degree. Otherwise they were good.
      Scott from NJ.
      Vent Windows Forever! ...
      Dec 2007
      Carlsbad, Ca
      im going with some v-bands from mandrel-bends.com. $40 for the 304 stainless clamp and two rings. way cheaper than anybody else, but he assures me that they sell a ton of them and that they are good.
      Tim
      Build Thread Link
      Feb 2010
      Quote Originally Posted by BonzoHansen View Post
      Yeah they are pretty wide, I started layout tonight and everything will be a straight clamp without any bends.
      BJ
      66 GTO LY6/4l80e
