Results 1 to 20 of 24
Thread: Why Does My Fuel Presure Drop
05-03-2010 #1
- Feb 2007
- USA, TN
- 850
I've installed an EZ-EFI system and it has been
trying to get it to run correctly. I couldn't get the engine above 2000 RPM. Everything seemed to be installed correctly. Finally got through to someone at FAST who could help trouble shoot and it turns out to be the fuel pressure drops to zero when I rev it up.
The fuel pressure is fine at idle. As soon as I give it gas, it drops to zero. It will recover a bit, but not much.
The question is, why is the fuel pressure dropping? I have a Ricks fuel injected tank with a Delco pump. I purchased this tank from a guy on ebay who never installed it. It looked to be unused. I double cheched and it looks like it is installed correctly. The supply is on the right and the return is on the left side of the car.
I also have an Aeromotive 13109 regulator with the return from the fuel rail going into the side and the return to the tank going out the bottom.
