Thread: Will long tube headers work?
05-02-2010 #1
I have an 1987 Monte Carlo SS and am about to drop an Lt4 in with the T56 trans. I really want to run long tube headers just not sure what headers will fit since the trans leaves little to no room for the exaust (slave cyl. location). If anyone knows or has a similar swap any help would be great. Thanks.
05-03-2010 #2I can't tell you these will positively work. The Hooker 2451 headers are 1 5/8" long tube and will fit a g-body with mechanical linkage. If they clear the clutch release fork on a mechanical clutch, they should also clear a slave cylinder. You might have to run some type of heat shielding.
I have (had/I am reinstalling) a SBC in my 86 Cutlass with an aftermarket T56 using mechanical linkage. I was using the Hedman shorties for an f-body (82-92) but even these had to be slightly modified.
I should have my 2451's tomorrow but it'll be a couple weeks before I get the engine back in. I was assured by several guys these would fit my mechanical linkage in the g-body.Doug Gulley
05-03-2010 #3
