      Mar 2010
      Clutch fork hitting firewall! Help!!!
      I have a 1967 firebird with a TKO 600 and a 1967 bell housing. I am in the process of hooking up the clutch linkage. When I push the clutch in the fork hits the firewall before the pedal hits the floor. Do I have the wrong clutch fork or assemble the clutch wrong? There is play in the fork before it requires pressure to release the clutch.
      Motor City
      If you are using an aftermarket clutch fork, most likely that is your problem. Use the correct GM clutch fork.
      Mike
      Henderson,NV
      Yep, stock GM is the key. Let me guess, heavy duty clutch fork?
      Todd
      Lawrenceburg, TN
      Thats a common problem I was running a 168 tooth flywheel and a zoom clutch(no clearance issues) we switched to a 153 tooth flywheel and a center force clutch, and had the same problem, after putting the stacks next to each other on the bench the new 153 flywheel was 500 thousands (1/2inch) thicker than the 168 flywheel and the center force was 250 thousands (1/4inch taller) THATS 3/4 inch TOTAL! and that moved the clutch arm into a larger angle and caused the arm to hit the fire wall I just massaged the fire wall for clearance or (you could look for a thinner flywheel or thinner clutch pack) hope that helps!
      build on!
      Lawrenceburg, TN
      I also tried both the GM and Lakewood clutch arms there was a better angle on the GM arm but it would still hit, the Lakewood hit sooner but after looking at the arms on the bench I opted to run the Lakewood arm (better constructed arm) compared to currently available GM part
      build on
      Henderson,NV
      You should've used an adjustable ball stud to get the angle right. Stock GM clutch fork and the proper angle will net no body mods.
      Todd
