Results 1 to 9 of 9
Thread: T56 question
04-29-2010 #1
- Oct 2009
- columbus, ohio
- 27
T56 question
after searching and reading until my eyes were pretty much bleeding, causing blood to drip on my keyboard i decided to give up. So that is my reason for this post...
My question is since all the "guts" of the t56 trannies are pretty much the same thing.. Can i use a mustang t56 for my a-body? I know i need to run a ls1 input shaft. i am planning on using one of the adaptor plates and using my mechanical clutch linkage for now. I will go hydraulic one day....
Will a ls1 input shaft fit a cobra t56? since I am going to have a driveshaft built, will i be able to retain the cobra tail shaft as well?
From what I can tell the major difference between the LS series, viper, and cobra trannies are the input shaft, the tail shaft, and bellhousings.. is that correct??
i hope someone can help me out here. i am just getting back into playing with real cars. I was working at a performance shop mainly building high horsepower turbocharged 9 sec. honda civics, i can tell you anything you need to know about a civic, but i'm lost with parts interchangeability when it comes to real cars.
thanks guys!
04-29-2010 #2As far as I know all of the factory t56 cases use the same input shaft bearing so yes the input shafts are interchangeable as long as the gear ratios are the same.
I can tell you for sure that the bearings in a 03/04 Cobra are the same as 93-02 F-body.Sean
The difference between stupidity and genius.... genius has limits
04-30-2010 #3
