      Scottsdale, AZ
      Lateral Dynamics suspension help???
      It looks like I don't have the correct hardware for the front link on the cross member. Does anyone know the parts I need and where to get them? There must be a flush style bolt to use because there is no way this bolt and nut will fit under the cover.
      Thanks in advance.
      69 SS/350 Camaro
      AME Front & Rear LT Build
      69 SS/396 Camaro
      LT4 Build
      71 K5
      May 2002
      Northern California
      You have to drill the hole through the plate. The plate goes on then put the bolt through then weld the plate in.
      Vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Scottsdale, AZ
      Vince
      Ah ha! Sometimes you have to take a step back and it becomes clear.
      Thanks!
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      May 2002
      Northern California
      No problem,
      I know that some guys have built their own boxes so they can access the bolts from underneath. I think they did this on the One Lap Camaro.
      Vince
