    Results 1 to 13 of 13
      Eastern Virginia
      Bolt pattern on small block chevy cam?
      Anyone know what it is?
      Scot
      86 Monte SS
      San Antonio, TX
      I would try Crane Cams tech hotline:
      1866 388 5120.
      HTH
      Aug 2006
      Easton, PA
      bolt pattern? you mean the 3 1/4-20 bolts for the timing gear?
      Keith C.
      Eastern Virginia
      Quote Originally Posted by twosaturns View Post
      Yep. I was going to make a cam install tool, probably easier to just buy one or see if i can rent from autozone huh?
      Scot
      86 Monte SS
      Aug 2006
      Easton, PA
      Quote Originally Posted by Samckitt View Post
      I would think so; by the time you fab one up, you could of had it installed by then.
      Keith C.
      Jan 2002
      Crockett, Texas
      Or you could just thread 3 extra long bolts in for a handle.
      Don 67 Camaro RS/SS Texas
      Rustburg, Virginia
      Quote Originally Posted by ZZ430 View Post
      Done that before. If you don't go crazy slamming the cam up into and through the bearings....it isn't all that bad without the handle. You can do it without nicking up the bearings.
      there are two different bolt patterns- the 55-95 flat tappet cams used a wider pattern than the 87-99 roller cams.
      i always just use an old long quadrajet mounting bolt. they have the proper 5/16" coarse thread and are the perfect length to make a good handle.
      Rustburg, Virginia
      Cut up an old timing gear(don't use the aluminum with nylon teeth version) and weld a handle onto it....
      Apr 2008
      Newark, OH, / Concord, NC
      Cam bolt pattern
      The bolt circle diameter is 1.235 for almost all 1st gen SB chevy's. Use aluminum because it is easier to work with, the plate that bolts to the cam can be either square or round, after you make the plate take some 5/16" bolts and bolt the plate to the cam loosely and hit it hard enough to make a witness mark for the cam dowel pin, remove the plate and drill it about 3/8" for dowel pin clearance. then either bolt or weld a 5/8"-3/4" piece of aluminum round stock for the handle, you can make the round stock to the length that you are comfortable with for the handle. It sounds complicated but it is really easy especially if you have or know someone that has some simple fab tools. If they are cheap ($50 or so) you would be better of buying one.
      Dale
      IF COMMON SENSE WAS COMMON EVERYBODY WOULD HAVE IT
      Eastern Virginia
      The cam is for a 95 motor, it is a roller cam with the thrust plate retainer, so i'm guessing it is smaller. I have seen them on ebay for about $20. Should just buy one instead of make one, or just use the long bolt as mentioned above.
      Scot
      86 Monte SS
      the long bolt is the easiest way. the longer the bolt, the more leverage you have on it. i just always use a quadrajet mounting bolt because that's what i've got laying around.
      Mar 2010
      Central IL
      Didn't have a long bolt was late nothing open so I welded a shorter bolt into a junk socket and used that along with an extension. Works great I have about any length handle I want now.
      Sean
      The difference between stupidity and genius.... genius has limits
