    Thread: what wires?
      Oct 2007
      ridgefield ct
      what wires?
      i'm looking at new wires, but am unsure of what i need.
      it's a chevy 383ci 73 block with vortec heads, HEI distributor, and afterburner headers.
      do i need larger than 8.0mm? do i need to buy ones for the original engine? does the Ohm/foot really matter on a street car?
      thanks for the help.
      Feb 2009
      muggy midwest
      You are gonna get a lot of various answers to this one but; the less resistance you have, the more spark energy you will be able to deliver to your plugs. Factor in underhood heat creating even more resistance, too. Now, I would look into upgrading the module and coil as well. The better your ignition system is, the more fuel/air you can light off and you will generally have a quicker starting and smoother running engine. Most people seem to neglect their ignition system until something goes wrong. with a more powerful spark you can open up your plug gap as well which can give you a bit of a boost. A nice ignition system doesn't add horsepower, moreover it releases a bit more potential that your engine had all along-a weak ignition system just masks it most of the time. For nice wiresets look at Taylor 409 or ThunderVolt, Magnecor or Moroso Ultra 40's. Those are about the best you can find. I wouldn't say they are overkill for the street-it comes down to whether you want the best wires money can buy and personally, for about $130, the 409's get my vote all day long-it's definitely NOT money wasted when you invest it in quality ignition components.
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      Apr 2008
      Newark, OH, / Concord, NC
      Quote Originally Posted by megaladon6 View Post
      You hear HP claims all of the time about this manufacturers wires v.s. that mfgs. wires, the best ones hands down are Delphi. They are used in NASCAR and NHRA Pro Stock racing not to mention others. These are high dollar wires ($600 for Pro Stock) but can be found on ebay very inexpensively, I have bought two sets there for my small block and paid $18 for one set and $34 for the other. Compared to other aftermarket wires (MSD, Moroso, Accel, ect.) they are worth about 6 hp and are very durable. And ditto on the previous post.
      Dale
      IF COMMON SENSE WAS COMMON EVERYBODY WOULD HAVE IT
      Jonesboro, Arkansas
      I use the Taylor my self...No problems .
      Carl
      Carl Wilson
      Aug 2005
      Hamilton, NJ
      I've used taylors w/o issue, now run msd 8.5s w/o issue as well.
      Scott from NJ.
      Vent Windows Forever! ...
      Feb 2008
      Sesser, Il
      Anybody ever used or heard good/bad about the LiveWires from Performance Distributors, makers of the Davis Unified Ignition?
      Here's the link for the Chevy wires: http://www.performancedistributors.c...vlivewires.htm
      Doug Gulley
      Feb 2009
      muggy midwest
      I forgot about those...I would rate them as pretty high on the quality scale.
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      Feb 2008
      Sesser, Il
      Cool, thanks for that info. I know where I'm getting mine then, since I just bought a new distributor from them, too.
      Doug Gulley
