    Results 1 to 20 of 25
      Saint John, NB, Canada
      Need some advice or maybe more...
      I am stuck guys. I've read, searched, read, searched for countless hours. I can't make a decision so I'm throwing the question out to the guru's.
      Currently I have a 68 Camaro subframe, sitting there with not a thing on it. I want to put it back on it's wheels. I am not going to be racing the car, just a driver with some performance. I want it to feel something like a newer car. So here's what I'm looking at/for:
      hotchkis TVS suspension
      spring and shocks OR coil overs ???
      upa/lca tublar or original ???
      original steering or rack and pinion ???
      power disc brakes (full bolt on packages? performance vs price?)
      iroc steering box
      solid body bushings
      del-a-lum bushings
      I keep getting overwhelmed when I start reading about all the different options, AFCO, ATS, AFX, hotchkis, dse, yadda yadda. I just need a direction and some knowledge from people in the know. I suppose a budget is needed. It'd be nice to know a high and low figure then go from there.
      PLEASE HELP!!!! thanks guru's!
      rookie
      May 2002
      Northern California
      Just a daily driver? Yeah I heard that before. Next thing you know you'll be at every track day within 400 miles.
      DSE arms, not really needed but they look cool. nice cause its Del a lumed Speedtech,globals,Hotchkis pick a set.
      Speedtech AFX tall spindles
      L&H Pro Billet F, X Body "Short" Steering Arms
      Hotchkis springs
      Bilstien shocks
      Hotchkis hollow sway bar
      Lee 600 box
      Solid bushings
      DSE sub frame connectors
      C5 front brakes
      Very nice, proven package
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      yeah daily driver atleast in the summer months... luckily there is no track within 400 miles of me or you'd probably be right. That's why I want to start with a solid base and be able to upgrade just in case.
      are the tall spindles going to affect the size wheels or brakes I can run? I'd like to get a matching brakes on all 4s... not that big of deal though. And are you saying forget about the TVS stuff and just buy what I would need??
      Who on this site can hook me up with a package like this at the right price?
      Keep the idea's comin guys, I know there's millions of them out there.
      Greenwood, SC
      Hotchkis springs
      Bilstien shocks
      Lee 600 box
      Solid bushings
      C5 front brakes
      Hey Vince, could he do the Gulstrand Mod in place of the tall spindles and upper arms to save on costs? I can't remember if the G-mod corrects everything that Tyler's tall spindle and upper arms correct. Just a thought if he's on a budget.
      Other than that, everything else that Vince posted sounds great. Most of the sponsors on this site sell this stuff, so just start calling them up!
      JC Scott
      What do these give me that my stock ones don't? How does it effect which brake package I go with as well? What would I need to keep as far as stock steering components? All of them or is it best to replace some of them?
      So it's possible I could just do something like this:
      Stock A-arms and some bushings (del-a-lum or rubber)
      Hotchkis springs
      Bilstien shocks
      Lee 600 box
      Solid bushings
      Then some sort of brake package like CPP or Kobe3 or something??
      Thanks guys,
      If you didn't realize it yet, I'm not good at this stuff and have had this car sitting in the garage for 5 years. Anyone have good experience with certain vendors?
      Greenwood, SC
      Quote Originally Posted by 72camaross View Post
      Hotchkis springs
      Bilstien shocks
      Lee 600 box
      Solid bushings
      Thanks guys,
      You need to do some more research (or this thread will get ugly lol).
      Read up on the first gen suspension here:
      http://www.pozziracing.com/first_gen_suspension.htm
      Then research the G-mod and look through the suspension forums here at P-T.com
      JC Scott
      Greenwood, SC
      This is taken from David's Website.
      <H2>Below is my response to a suspension geometry question from the Team Camaro Forum
      The question relates to the Guldstrand mod and if lowering the upper A frame more than Guldstrand recommends, or using a taller spindle plus the Guldstrand mod to get more negative camber gain is a good idea.
      Please understand that you can't focus ONLY on camber gain. As they say, a little knowledge is dangerous, and in the case of suspension geometry I feel it's VERY true. If you are going to change anything from stock, it's a good idea to understand all the ramifications of your "improvements". Since most everything concerning your suspension is interelated, one change usually affects other aspects of your suspension.Changing upper A frame mounting location will change:
      • Camber curve, or gain.
      • Side scrub of the tire tread.
      • Bumpsteer
      • Roll center height, and amount of RCH movement- up and down and SIDEWAYS! (not kidding)
      • Roll stiffness
      The roll center height affects driver feel, roll stiffness, how much of the cornering roll torque is fed through the springs, shocks, sway bars, vs how much is fed directly via the geometry to the tire.
      EXTREME EXAMPLE: If the roll center were raised to the same height as the center of gravity, NO roll torque would be fed through the suspension at all! The car would not be tuneable by changing sway bars or springs!
      SO lowering the upper A frame usually will raise the front roll center, increase the neg camber gain, increase tire side scrub, the higher roll center will move more - the more you lower the upper A frame mount. If it get's too high, the tires will tend to break loose if small bumps or undulations are hit in a corner. The suspension- springs, shocks, swaybar, should be softened to accept the resulting lowered roll torque generated.
      The starting point "should" be the tires, and what they require for best performance. Some tires need more negative camber than others.
      You should temper tire requirements with the application, street, track, drag, roadrace, autocross, type of track, type of pavement, banking, bumps, etc.
      They all have specific requirements from geometry to setup, and how much wear can be tolerated. I assume you would be concerned if your front tires wore out the inside edge in 500 miles?
      You would then set up your suspension geometry, springs, swaybars, shocks, alignment, to best work with "that" tire.
      The Guldstrand mod lowers the upper mount about an inch or just a bit under that.
      It retains low tire side scrub, stable roll center movement and height, some beneficial negative camber gain.
      Consider that my 89 IROC camaro had 1/2 to 3/4 degree static neg camber with the adjsters moved all the way in. The McPherson strut suspension added little in negative camber gain during roll.
      Late vettes have similar neg camber gain much less than the Guldstrand mod. I don't have the figures, but the A frame angles I see lead me to that conclusion.
      The newer radial tires have SOME ideal requirement for camber. But I don't know what that is! THAT is the burning question, and the starting point for the suspension geometry improvement proccess.
      That data is generally only known by suspension and tire engineers.
      TRADEOFFS.
      Why not lower the holes more than Guldstrand did?
      More negative camber gain might be better, but it could easily be worse in other areas.
      You brake hard at the end of a long straightaway, now the tires are unevenly loaded on the inside edge during straight ahead braking! Result-poor braking, wheel locking.
      Example two, you brake hard and turn into a corner, - all is good, you then get past the middle of the corner, get on the gas, the front end raises up under acceleration, now the camber curve goes the other way! The tire will lean out more! Your increased neg camber curve cranks camber out of the outside front tire, is that good? Result- corner exit understeer.
      You enter a long high speed sweeper, the car is under power, front lifts a bit higher than static ride height due to power applied and aero lift. BUT you need to corner hard, you are on a flat curve going 90mph. How much negative camber did you lose? how much understeer are you going to have?
      The best I can say is "dont' get greedy", people do break the rules sometimes, I've seen some crazy stuff work and win, especially on a circle track sprint type car. Those guys have some wierd ideas! But, circle tracks do not have flat or off-camber corners.
      TUBULAR ARMS VS THE GULDSTRAND MOD
      The Guldstrand mod increases negative camber gain, when the car leans (rolls) in a turn, the tire will not lean out as much as it does with stock geometry. It will also raise the front roll center making it more compatable with the rear roll center height.
      Stock upper A arms can achieve around 3 degrees positive caster. "Properly" made Tubular upper arms allow higher positive caster alginment settings with pretty close to the same amount of shims front and rear. Increased positive caster from tubular upper arms can eleminate the tire leaning out when turning sharply. Steering effort will increase, but if you have power steering it won't matter. There are also dynamic weight jacking effects from high caster.
      Park your Camaro on level ground and turn the wheels to the right to full lock, the left front tire will lean outward, (positive camber) by about 3 to 4 degrees, increased positive caster of around 5 degrees will keep the tire vertical. Remember the chassis will dive and roll in a turn and you need excess neg camber gain to make up for that.
      A First Gen Camaro has 8.75 degrees steering axis inclination* (SAI) built into it, If you were able to turn the front wheels sharper to a 90 deg turn, the wheels would camber out by 8.75 degrees, minus any positive caster you have set. You can't turn your front wheels that sharply, but you can turn them around 26 degrees, which is almost 30% of 90 degrees.
      In general, more neg camber gain via the Guldstrand mod will help most on large sweeper type corners, - generally high speed turns.
      The tubular upper arms will allow 5 degrees positive caster with minimum shim stack which isn't achieveable with stock arms, usually 3 deg + is all you can get. Large amounts of caster tends to help most when the wheels are turned very sharply, like at an autocross, but it does help a bit on larger radius turns. The nice thing about positive caster is, it goes away when you point the wheels straight ahead, so you can use less neg camber setting
      * SAI, Steering Axis Inclination, draw a line from top balljoint to bottom balljoint this is the rotation axis of the front wheel, a First Gen Camaro SAI is 8.75 deg from vertical with the top balljoint closer to the center of the car than the lower.
      </H2>
      JC Scott
      Quote Originally Posted by cheapthrillz View Post
      haha thanks for the input. That stuff is way over my head and I won't be doing any racing. It is a driver so I think I may be ok with just stock components then if I ever want to upgrage I can pick up some tubular arms.
      trust me I've been reading pozzi's site and PT and Camaros.net for a while trying to find a solution that fits my needs/budget and that overal I'll be happy with.
      Greenwood, SC
      Most of it goes over my head also..... I think the main thing that seperates the performance handling characteristics of a first gen from a new car is.... god help me.... "the poor suspension geometry".
      David Pozzi would be the guy to talk to about your situation.... He (and others) "tried" to help me with my Father's car, but it wasn't in the budget and the subframe had already been painted.
      Here is the thread I started. Same kind of questions as yours:
      https://www.pro-touring.com/forum/sh...ad.php?t=32401
      JC Scott
      I read your thread. It is very similar to what I'm looking at. I do want to correct some of the geometry now and get a good ride height and stance.
      I wonder if I could get away with the GW uca/hotchkis 2" drop springs and shocks/SSBC brake kit.
      How do you like that kit?
      The thing with the ATS spindles is I don't know if I'll end up with C5 brakes or not and don't know if I want to spend that much. I think I could be happy with the stockers
      Phoenix, AZ
      If you are looking to save money you can run with a Hotchkis suspension and it will be fine for what you want. Do a nice base system and dont go overboard. You dont need all the other stuff unless you want more. Your car with uppers and lowers will run great and only if you want to blow the extra coin do you need to keep going. Everyone wants to sell products but if you are on a budget and want a great driving car Hotchkis and Global West have great inexpensive systems to run.
      Chris Fesler
      Aug 2003
      Your asking our number one Project Planning question. And we sell and build mild to wild set ups starting with Hotchkis TVS all the way up to AME and DSE set ups, and everything in between.
      Having a full line of products, we can help you get the best products for your project, not the best for our pocket book since we will make a few pennies no matter which product you buy.
      Quote Originally Posted by Fesler built View Post
      Are you talking stock uppers/lowers or the GW? I'm thinkin pretty mild is all I need.
      Quote Originally Posted by ProdigyCustoms View Post
      Thanks! I was hoping you'd pop in. I think all I need a mild street set up that will give the ride height and stance I want. Maybe you can PM what you'd recommend along with the stock parts I have and we can set something up.
      Greenwood, SC
      You'll probably have to call Frank and talk to him. He stays busy. If you called him and told him your budget, he would definately hook you up with the best system you can afford. And at a good price.
      JC Scott
      Oct 2009
      Reno, NV.
      I'm in the same boat, except I've pulled the trigger and started putting this stuff together. Hopefully, it will give me what I want. Here's my setup for my '67
      • welded the stock subframe
      • global west upper arms (poly bushings)
      • stock lower arms (poly bushings)
      • Guldstrand mod
      • Global west solid sub frame bushings and subframe connectors
      • Good quality lowering springs and a nice set of shocks (still need to purchase)
      • still need to pick out the steering box
      Joe M
      '67 Firebird
      My build thread: https://www.pro-touring.com/showthre...irth&highlight=
      Quote Originally Posted by 67rstbkt View Post
      • Guldstrand mod
      Do you mind if I ask where you're at $$ wise? If not that's ok. You can PM if you prefer. You basically have started pulling the trigger on the stuff I'm looking at and thinking about. What do you plan to do for brakes?
      Oct 2009
      Reno, NV.
      Sure, no problem. I've accumulated some of this stuff as deals come up so the pricing may vary from what it costs brand new. If you check the for sale section on this site and lat-g, you can find good deals on new stuff.
      I found a subframe locally that was in much better shape than the one I had. The guy had basically stripped it down, converted to a stock type disk brake setup, and changed all the bushings out to poly. That cost me $700
      Global West upper arms (poly bushings): purchased in the for sale section from another member on this site: $375
      Guldstrand mod: Can be free, but I purchased the template for $18 from Guldstrand motorsports. I figure they probably deserve something for it, even if it's just a piece of paper.
      Welded frame: free - I welded it myself, so just time
      Global West Solid sub frame mounts: about $100 from Summit racing
      Powdercoat: I stripped the frame down to metal and found a guy that gave me a good deal (I think): $250
      So the total so far is: $1443
      I still need to buy shocks, springs, and subframe connectors. I'll most likely use the disc brake setup that came with the subframe I bought (at least for awhile). Everything was brand new, the guy did all the work, then went a different direction, so I should be able to reuse most of the rest of the steering components and lower control arms. I posted some pics of where my subframe is at in my build thread. I should have it mounted up by this weekend and will be starting on assembling the suspension soon after.
      Joe M
      '67 Firebird
      May 2002
      Northern California
      Hotchkis springs
      Bilstien shocks
      Lee 600 box
      Solid bushings
      Thanks guys,
      We put a set of AFX spindles on a customers car with stock arms rebuilt with ES poly bushings , a chopped MOOG BBC A/C coil spring, a Hotchkis bar and an ATS/Lee box. It rode so well and improved the the down falls of the stock suspension. The customer was very happy.
      Thats a cheaper list, you can even get down and dirty with the shocks and springs but honestly...
      Of all the Items I have listed the AFX spindle should not be a list throw away, should be a staple.
      Over stock spindles You get:
      real proven geometry improvments in camber gain, "substantial bump steer improvments without the tirewear"
      "a large sealed bearing hub". Reduces brake noise and gives an overall road feel of smooth.
      "Easily mount larger C5 C6 brakes".
      "Lighter than the factory spindle".
      "" = 4 things the Guldstrand mod does not address.
      I always recommend DSE arms because it has Del A lums and for the caster gain so you don't have a crazy shim pack.
      Toss the parts list around to save cash but the AFX should be a given.
      I know how these threads go and everyone gets butt hurt but these add ons are what I do and would do on my own cars. I am not going to get into a big bash about my recommendations cause you can take it with a grain of salt or try it out. I have yet to receive a complaint (not counting ugly welds).
      72camaroSS if you want to save money, go with Frank at Prodigy customs. He will beat anyone on the planet. With his ties with Speed tech you will be very happy. If it helps with your budget, I will give you a set of my weld in subframe connectors, just pay for shipping. PM me if you are interested.
      Now this is for adding on to a stock frame, if I had a no bottom sky's the limit budget, then I'd go full DSE sub frame. Next in line would be Jake's Rod shop frame.
      Vince
      Greenwood, SC
      Ahhhh...... Knew I was missing something important.
      Prop's to Vince for the subframe connectors too!
      JC Scott
