    Page 2 of 2 FirstFirst 1 2
    Results 21 to 36 of 36
    1. #21
      Quote Originally Posted by staged67gspwr View Post
      here are some pics i took today you can clearly see where the seal ends on the yoke.
      Does the inside of the yoke go to where it appears to end on the exterior of the yoke?
    2. #22
      NYC
      no the end of the output shaft is further in the seal.
      George
      `67 Buick GS 400 Hdtp,494ci Stage 2 BBB,5-speed TKO-600,"The Black Widow"
    3. #23
      Dec 2007
      Carlsbad, Ca
      dont worry about the seal since it can and will be pushed away by the yoke as needed. if youre worried about it being too long its really simple to tell. put the stands under the rear so the weight is on the axle, disconnect from the pinion yoke and slide the ds as far forward as it will go. you will most likely have to push hard if the seal hits before it bottoms out. if you have ~3/4 - 1" of forward movement youre good to go. most likely if you were able to install the ds without too much effort, its not going to be too long.
      Tim
      Build Thread Link
    4. #24
      NYC
      Yea i am able to push it forward to put the shaft in
      George
    5. #25
      Dec 2007
      Carlsbad, Ca
      well the u joint caps are all larger than 1" which means you have at least 1/2" of clearance. if its not tight going in you have even more. you shouldnt have an issue with it being too long.
      now back to the new whine.....
      Tim
      Build Thread Link
    6. #26
      Personally I think that your driveshaft is the perfect length. It is as long as it can be while still allowing easy installation. In my opinion it is definitely not bottoming out while you are driving.
    7. #27
      NYC
      You know maybe that "whine"was there and i just never paid attention i dont know i just dont remember hearing it.the other thing i noticed last night i got on the car hard and 2 times it did not want to go into 4th gear where usually goes in like butter??I dont know if this is all related?
      George
    8. #28
      Is your clutch not disengaging all the way?
    9. #29
      NYC
      It only did it twice and it didnt do it again the clutch is adjusted fine,maybe my tranny is used to steel heavy driveshafts and doesnt like the less rotating mass of the CF shaft?lolololol
      George
    10. #30
      Anything is possible. I would just drive it and see how it goes.
    11. #31
      NYC
      Thanks guys!!
      George
    12. #32
      George
      We can estimate (OUR) drive shaft length by looking at how much yoke is showing beyond the seal because we KNOW the yoke and sell lots of them. With other yokes the output shaft can bottom out shorter or longer because of the design of the yoke. I would recommend that you bottom the yoke out (push it into the back of the transmission as far as it will go) and make a measurement. Then hook the drive shaft up to the pinion yoke and make another measurement. The industry standard (depending on who you talk to) is 3/4" to 1". We use 7/8". So when the suspension is traveling you have a 7/8" buffer. I feel safe with 1/2" with most muscle cars because the suspension is usually beefed up and doesn't travel like a grocery getter. If you have a 4 link or truck arm suspension you could get away with less. The whole objective is that you don't push the transmission output shaft forward and do damage. The trans whine is likely caused by some part of the body touching the drive train. If it didn't do this before I would check to make sure you have slip yoke clearance and body/frame to drive line clearance.
      Jim
    13. #33
      NYC
      Jim,i had the slip yoke you guys use on my steel shaft,its the same measurements as my new one from Mark Williams slip yoke,i can push the slip yoke into the back of the output shaft enough or else i would`nt of been able to remove the driveshaft to clear the rear yoke,i dont have any clearance issues with anything touching the drivetrain,i never did,i`ve put 6k miles on this car and drivetrain in 3 years with the steel shaft without an issues so why would anything be touching now?
      George
    14. #34
      NYC
      Just for reference the slip yoke barrell is 4 1/8 long
      George
    15. #35
      As long as the new yoke is the same, yer fine!
      Jim
    16. #36
      NYC
      Quote Originally Posted by GMJim View Post
      Jim
      thanks Jim.
      George
