    Results 1 to 20 of 24
      Dec 2009
      El Dorado Hills
      What Spring Rate for Road Racing
      I have a '69 Camaro With Global West arms and conventional spring set up. If you were strictly road racing car what rate spring would you use. I am contemplating 850 lb right now.
      Gaetano Cosentino
      Dont Drive Faster Than Your Angels Can Fly
      May 2002
      Northern California
      depends, how does your current set up feel?
      vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Dec 2009
      El Dorado Hills
      vince
      I,m running about 715 lb(cut a coil off of 650 lb) and it felt fine road racing but pushed in my first ever autocross.
      Gaetano Cosentino
      Mar 2010
      Central IL
      Going to a heavier front spring will make it push even more to loosen it up you need a softer front spring/bar or a stiffer rear spring/bar.
      Sean
      The difference between stupidity and genius.... genius has limits
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by LSx_88_Ciera View Post
      Hmmm... Global West is telling me to go to a 800 lb spring. I've tried a higher rate leaf spring and I was too loose.
      Gaetano Cosentino
      Mar 2010
      Central IL
      Are they aware that the car is pushing?
      I don't know why they would suggest a stiffer front considering going softer on the end that needs traction is tuning 101.
      Do you have provisions to adjust the rate of your rear bar?
      Have you tried reducing air pressure in the front tires a pound or 2?
      Is the push on entry, mid, exit?
      Sean
      Dec 2009
      El Dorado Hills
      I'm thinking autocross and road racing are two different animals. Slow speed thrusts into tight turns with alot of torque when auto crossing, and in road racing, a continuos flow to where it is much easier to set up for a turn and have chassis pointed in right direction.
      Although, I was not prepared for the autocross event(due to thought it was gonna rain and then last minute jumped in my car and showed up late)so I didn't bring my air tank or tire pressure gauge and when I borrowed a pressure gauge noticed i could have taken a few pounds out of front tires.
      Gaetano Cosentino
      Mar 2002
      Redwood City, CA
      You could be ok right now up front. What leafs are you running out back? You could run an adjustable rear bar. I know Global West doesn't recommend one, but it IS a tuning device. Adjustability is key. And if you find you don't need it, you can always disconnect it or take it off.
      Allen Ortega
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by zbugger View Post
      I'm running Global West rear leafs and had them de arch them an extra inch. I starte with Hotchkis rear leafs and they had me loose as hell. I think the stikier the tires and the more power you definitely need a rear bar contrary to what Global West says. I'm due for front springs cuz my front left is sagging from road course abuse so i was thinking of stiffer springs. Guess I'll find out at Buttonwillow June 5th. Who makes an adjustable rear bar?
      Gaetano Cosentino
      Mar 2010
      Central IL
      Quote Originally Posted by Gitter Dun View Post
      Hellwig
      Sean
      Rustburg, Virginia
      I agree with LSx 88,
      Generally you want to soften up the end that doesn't have grip....ie. the front is pushing, so you would take some rate away from that end or add some rate to the rear. Depending on how much it's pushing.
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by John Wright View Post
      Thanks guys, your input definitely influenced my decision. I will probably stay with the same rate spring up front rather than go to 800-850 lb and start shopping for the Helwig sway bar.
      If it all goes to hell I'll just blame you guys, LOL. JK
      Anybody have any photos of a Hellwig Install? Do I use the solid or hollow bar?
      Gaetano Cosentino
      Mar 2002
      Redwood City, CA
      You can use the hollow bar to save a little weight. I know the Hotchkis rear bar is three way adjustable and the install is pretty simple. The Hellwig should be similar.
      Allen Ortega
      Dec 2009
      El Dorado Hills
      Cool thanks. I just pulled springs and one is 1/2" shorter than other. Thats what you get from 3 years of hard driving from a set of global west springs. I started getting slight tire rub lok to lok on fender on sag side. Good side spring length is 12" and I'm running 275 40 17's with stock subframe. Now I,m going to see if Eiback has springs I need, if not, back to global west.
      Gaetano Cosentino
      Mar 2002
      Redwood City, CA
      I hate Eibach springs. Especially in a muscle car application. Don't ask me why, but I do. I'd recommend going back to Gobal, or even try a Hotchkis spring out. Quite a few here have had success with Hotchkis front springs. I think Mary has been running Hotchkis front with Global Cat5 rears with plenty of success. Oh, AND a rear bar. My car is slowly becoming a copy....
      Allen Ortega
      Dec 2009
      El Dorado Hills
      Regardless, and maybe luckily, Eibach didn't have what I was looking for. Global West want's $189 for springs. I hope this doesn't turn into you get what you pay for but I went into Afco's web site and found 700 lb springs for under $50 each and purchased them. At that price I might pick up a couple of more spring rates and due some test and tune.
      I think the adjustable rear bar is important especially because I think a road race tune is different from an autocross tune.
      Gaetano Cosentino
      Jul 2008
      antioch,ca
      i'm running global west cat 5 front and rear. front is coil over adjustable w 650 lb spring rate. rear has like a heim joint welded in to flatten tire when corning hard. i couldn't be more happier have a small leak at steering box(agr variable) and rear pinion to housing slight drip. working them out, cant wait to get to the track.
      David Badley
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by 676869addict View Post
      I am organizing a Buttunwillow track day for June 5th with NCRC. $99 for 5 20/25 minute sessions. We would love to see you there.
      Gaetano Cosentino
      Henderson,NV
      Personally, I feel autocross is much harder to get a good working car. From brakes to feel. I really like the feel of my car on the road course. Going fast in autocross is always going to be a compromise. I really think autocross calls for a really stiff car to keep the body roll out of it. You watch that TCI camaro. That thing looks suspension less. It didn't fair so great on the big track set up that way.
      Todd
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by Vegas69 View Post
      I couldn't agree with you more, and I'm not willing to compromise my road course set up for an autocross set up, but I think an easy fix/compromise would be rear adjustability with sway bar.
      Gaetano Cosentino
