      Nov 2009
      Ca
      67 camaro/firebird
      Whats the best way to mount auto meter speed and tach gauges into the stock holes on a 67 camaro/firebird?
      Melbourne, FL
      Quote Originally Posted by paint2361 View Post
      Do a search for this and you should find several threads. I'll see if I can find some pics I saved that are posted on this site.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Melbourne, FL
      Here are three pics I found that were originally posted on this site. But do a search and you should find more info. Also take a look on camaros.net. Good site for 1st gen camaro info.
      Manitoba
      My recommendation would be the covan's dash panel.
      http://www.classicdash.com/shopping/...&cat=52&page=1
      One will be going in my wife's 67 this spring.
      72 formula ls1 tko600
      71 gmc c10 project
      Melbourne, FL
      I actually used a blank Covan dash to mount my 5" speedo and tach in. Here is a link to my setup. There is also a template on how to cut the openings for the gauges.
      https://www.pro-touring.com/forum/sh...ad.php?t=23795
      http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
      I found these on eBay. Thought they looked pretty cool. Kinda pricey.
      Also has a set to mount 1 5" gauge, and 4 of the 2 1/8" gauges in the other spot.
      Melbourne, FL
      Interesting item. I hadn't seen those before.
