    Results 1 to 11 of 11
      Apr 2008
      La Verne CA
      rear gear recommendations
      I am build a street car with 383 with twin Turbonetics TO4B 60mm turbos feeding a stealth ram with FAST EFI. Engine is backed by a Turbo 400 and vehicle weight is 3600 pounds. Motor is producing about 800/800 at 14 psi and would like to hit low 10s on the strip but also want some decent cruising gears. what rear gear should I go with? I was thinking a 3:27 or a 3:42 ratio as the torque builds very quickly and I don't want a car that is only good for John Force burnouts.
      Thanks in advance for the recommendations.
      Feb 2002
      Springfield, MO
      My vote goes with a 3:27. The TQ down low will pull thru and build boost better with the extra "load". IMHO
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      Apr 2008
      La Verne CA
      Quote Originally Posted by shmoov69 View Post
      Thanks, that is exactly what I have heard concerning turbos and loading. That will allow me almost 75 mph at 3,000RPM (w/ 18" tire) which isn't all that bad considering I have no overdrive. Will probably break down and buy a gear vendors unit.
      Feb 2002
      Springfield, MO
      I have 3:00 in mine, and I like it, but they may be a hair tall for getting out of the hole. But I love the drive manners!
      Jimmy
      Jan 2010
      Delaware
      I'm going with 3.08's in mine shortly, after having 3.73's in there. I need more pull time in each gear for the turbo to spool and use the energy it has on tap. As it stands right now first gear is almost useless for me and I shift almost immediately to second......not there all that long either. A lot of the pontiac turbo guys seem to prefer 3.08s.
      1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
      Mar 2010
      Alabama
      I am about to crank mine for the first time today and get it tuned. I am running twin 57mm turbos with a 355 but will be converting to 383 this winter. I currently have 3.73 with a built 700r. I know you see 700 r and wonder why I go that way but my builder guarantees it to hold whatever I throw at it. Do you think 3.73 is too low of a gear for my setup as well.
      Aug 2008
      Hutto, Texas
      You will be in first gear for a second (or less). Not the best combo., IMO. I am curious to see how long the trans. lasts.
      Honey, I don't know how those black marks got on the driveway....
      Feb 2002
      Springfield, MO
      Well, the trans will last longer with 3.73's!! Lol. But the gear is waay too short for turbos IMO. I really like my 3.00's but the next step ip wouldn't be bad.
      Jimmy
      Mar 2010
      Alabama
      I thought about running a 3.08. Any of you running street radials if so what size and kind. I figured with the low first gear in the 700r and the 3.73 i figured it would be too much on take off and just blow the tires off.
      Mar 2010
      Alabama
      As far as the tranny goes, he has built racing trannys for years. He had an S10 with 4.56 gears that he would drive to the track and run mid 6s in the 1/8th. It could have been better but couldnt hook that good because of the S10. You guys may not think this is much, but IMO it is good lol.
      Aug 2005
      stockton,ca
      Another vote for 3.08's.
      69 Camaro
      491BBC/TH400/GV OD/9"
