header hitting subframe on 1st gen
i started my car today and i heard that the header was tapping on the sub frame on the passenger side, this was never a problem but after the motor re-fresh it has been doing it. i have a bigger cam in the car now and it seems that when it idles at lower rpm`s it taps constantly, what should i do???-dom
Dom Buffa
04-14-2010 #2do you have rubber original motor mounts if so try stepping up poly mounts
David Badley
04-14-2010 #3i have the poly mounts in there as we speak,l changed them when i did the motor swap, i don't know what i should do because it doesn't sound good at all-thanks dom
Dom Buffa
04-15-2010 #4Headers
Hey Dom sent you a pm.
