      May 2006
      Rhode Island
      WTF- new bushing sleeve aggravation
      Ok, noob time, I'm having one he'll of a time putting the new bushing sleeves in the control arm!!!!!!! Is it normally extemely difficult to put these suckers in? I'm using a hand press at work, I've got the bigger sleeve in for the most part, but of course not without a battle, but the smaller one almost seems to big, even to be pressed in!!! I have to take a sanity break now
      Rene P.
      May 2006
      Rhode Island
      this is the bigger one, is it in far enough? I can't get the friggan thing to budge anymore.
      Rene P.
      May 2002
      Northern California
      They can be a pain if not prepped right.
      You can see that the arm is actually caving in.
      I always clean up the sleeve surface with a sanding flapper and then I made a bunch of half moon supports from roll bar tubing to support the control arm sides so they do not collapse when pressing as they did with yours.
      Put you arms in a vise and gently tap the outer edge with a hammer. It should bend back straight. A long flat dulled chisel should help get in the tight spots. Also have someone hold the arm with the sleeve flat on a hard surface.
      Vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      May 2006
      Rhode Island
      Ok, I ended up dropping them off somewhere that has the right equipment and know how, my mechanic!!!!!
      Rene P.
      Marshall , MO
      I used a peice of square tubing to support the flimsy arms when pressing out my old bushings it should work for pressing them in as well.
      Brad Shepard
      69 Malibu
      Marshall, MO
