    Results 1 to 1 of 1
      Apr 2010
      Mix-Match Build 350cu.in. (MAYBE)
      Im building a1972 350 and Im up to deciding on what carb to use so I called (BG) Demon carb Techs and they said I have a mix match build
      and the manifold will not work ,and the cam is not for build.
      As I was building this engine I was on the phone constantly with all
      techs from Eldebrock,Comp Cams,Summit,Jegs,Speed Pro,Holley,and
      the Carb shop and they all thought this build would work.
      The engine is still on the stand so im willing to RE-DO and make it
      right.Heres info on the car its going in;1972 NOVA SS with 4 speed
      stick,3:42 posi rear,wheel size im not sure yet might be 17"or 18"
      wheels, and the intended use will be weeknights and weekend cruises
      and getting on the highway and open it up. I am the original owner.
      Here is a list of the parts in the build:
      350 block bored .030 0ver .100 domed pistons speed pro hypereutectic
      projected compression RATIO 9.3-9.5, cast iron heads 76cc combustion
      chambers ; intake valves 1.94 exhaust 1.50 , heads machined .002
      3 angle valve job , head gasket thickness .042 no porting work.
      stainless valves, roller tip rocker arms 1.52 ratio
      comp cam thumpr# CCA-12-600-4 cam specs rpm range 2000-5800
      duration @ .050 intake 227 exhaust 241 gross valve lift intake .479
      and exhaust .465 , flat tappet HYD lifters
      performer RPM air gap manifold. Hooker super comp headers 2 1/2"
      exhaust with X pipe - magniflow.
      I need to know what needs to be changed: manifold, CAM, or heads
      I would appreciate any input/advice . If OK, need to know what
      kind of carb. and CFM .
      lam72
