      Apr 2010
      71 Monte Carlo interior
      I need some help if anyone knows anything about Fisrt Gen Monte Carlo interiors. I have a chattering noise that gets louder the harder you get into the throttle but doesn't do it a cruising speed. Believe it to be the speedo cable but not sure...any advice/pointers??thank you
      Sunny Florida on the Suncoast
      The speedo cable probably needs to be lubed. If you can get to it from the back of the speedo disconnect and shoot some light grease down the cable. That is why I lubed mine the last time the dash was out of my Monte Carlo (70-72 Chevelles are the same). Could be a bad speedo head too. The plastic dashes are pretty noisy in the later Chevelle and Monte Carlo (I know mine is).
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
      Erie, PA
      Ditto
      Andreas
      www.fgmcc.com
